Aww you don't like it, don't read it.Eye roll..............Here we go, yet again.........![]()
Aww. Smile, it's Friday and a New Year. If you hate the content here then why do you read threads?I read it, and posted my opinion. If you don't like it, don't read it.
Yes use the search. No, would not be stagnant, what is stagnant is the same questions that has been asked over, and over, and over for years on end.
that, is stagnant. The search area is there for a reason, and I assure you it would not be there if it was perceived to make the forum stagnant.
Why don't ya ask if a about Cat Vs. Non cat stoves while your at it. Don't think that subject has been breached quite a thousand times over yet.
Heck if people aren't supposed to start threads then why even register as a member. Everything is already here to read right?I said what I have to say. None of which said anything about hating content.
The beauty is, I can read or not read what I choose. I can also respond or not respond, also, as I choose.
Most searches are for standard questions, such as this one. Actually, this is the perfect example of why to use the search.
But never the less, the questions will pop up again, and receive all sorts of answers, again.
You being a member of many forums, I would expect you know this already.
You want to rinse & repeat, have at it.
Let me know what new insight & opinions from those already stated over the years, you have come across.
Welcome to the Hearth
Thanks bud. I hope you have a good weekend. Thank you for your help on my question, your clarification on you as a person, and your forum advice for me. No hard feelings, have a great evening.Rude? Obviously you don't know me well. There are those here that know what me being realistic, and me being rude are.
Obviously, your well seasoned memberships on all those manly forums you belong to, have not thickened your skin much, Bud.
So sorry to see you get your panties in a bunch.
Again, I said nothing about not starting threads.
Seems you're one of those, that like to stir the pot, then put words in others mouths, to prove some kind of point or argument.
Sorry, Bud! Not gonna happen here.
I see em come and go, every year. Some stay, and contribute, fewer stay and like to stir the pot, and many more hit and run and disappear.
I suggest you stop attempting to put words out as from me, to further your view, and instead thicken your skin, or simply take the advice on a search.
I was not being rude, until you asked for it, but have still been pretty mild.
As to answer your original question:
I have both, and have used both. I have also contacted the manufacturer of my lining system, at the time DurVent. The tech advised either is fine, and neither would harm the liner.
From my own experience, the poly does not clean as well, and is stiffer to get through the flex area. And cannot be used while the stove is in use or piping is hot. The steel cleans very well, is much more flexible and does not get hung up on any tight spots. I still use one or the other, depending on which I find closer at the time of use.
There are many on here that use one or the other, swear by them, and have their own preferred one to use. So if you're looking for a definitive answer, call your pipe manufacturer and ask them directly.
Yes I was a newb as you put it, at one time. And I also didn't give those attempting to give me direction, attitude, or disrespect.
I am done with this, and you. You may go.
we use soft bristle stainless brushes on most stainless liners but it is a safer bet to go with poly you should never use a regular steel brush in a stainless pipe.
We use the stainless bristle brushes on all ss liners but the double layer smooth wall crap.Bholler when you say "most stainless liners" are you also referring to light-wall flex liners or only heavy wall?
I see this crap all the time on other forums time and time again, too lazy to do a search, and it is not polite to point gunsHeck if people aren't supposed to start threads then why even register as a member. Everything is already here to read right?
I'm on many gun, hunting, chainsaw, and truck forums. Not all long term members are rude to new members. Everyone was a newbe at one time, even you bud!![]()
The other thing is there are different types of poly brushes and some are much stiffer than others and near impossible to reverse in the pipe which can be a total PIA.
