Polish versus paint on a Quadrafire 3100
Wyodaniel
5
WY
I picked up a used Quadrafire 3100 ACC, and it was a little rusty in a few places, mostly along the top. I used a wire wheel and a rough buffing pad on every exposed surface already. To make everything look clean and flat black again, I'm realizing that I have the options of either stove polish or high temp paint. I'm also realizing that there's some different surfaces and I'm not sure if they needed to be treated differently; I have the thick metal slab directly on top (green arrow), and some thin little heat shields with an air gap behind them on the sides and the back (red arrows).
[Hearth.com] Polish versus paint on a Quadrafire 3100
I don't what metal each component is made out of, and what kind of surface finish is more appropriate.
Any advice? Thank you!
The answer is always paint. Polish was only a good choice before high temp paint was invented
Reactions: bigealta
Read somewhere(maybe here) that multiple thin coats is better than 2 thicker coats. My stove was is way worse shape than yours, I started with a scraper on the rust. I went with very thin coats, probably 5-6 coats, the first 2-3 coats seemed to get sucked into the metal much like primer on wood. Acetone was recommended to prep for painting, didn’t have any but had gallons of wood alcohol so I used that.
Reactions: Wyodaniel
