How does the Pferd avoid raising the tooth file out of the gullet if the rakers are too high?
Do you have ripping chain or something? A 2 in 1 should work for any cross cut chain if you get it in the right pitch.
I am pretty quick with the Granberg, but I use it all the time. The thing that takes longest is getting the back stop adjusted right. To make things faster I put the jig in the same place, or close to it, every time. There's an older guy on youtube that is a wizard with his, but it's the older version. I'm not positive, but I think the Granberg wizard is also the author of this blog which goes into incredible detail on how to use the Granberg file jig to sharpen square ground chain with a three angle file.I have been using a Pferd (and a pair of calipers for measuring teeth) most of the time and a Granberg jig for overhauls.
I am currently making the jump from Granberg to an Oregon 520 grinder. Will still use my Pferd for 4 or 5 sharpenings, then use the grinder to get my angles and lengths back.
It's not something I needed to do, but I wanted to be able to bang out a couple chains on my way out to the woods, and that is not the speed the Granberg hand filing jig runs at.![]()
I looked at them the last time I was at madsens. Bob took me back where they have a couple set up to grind chains for customers. The only thing that seems wanky is how they dress the stone. It’s a pig and a poke looking setup. Bob said it doesn’t really matter too much how the stone is dressed but it makes me wonder. I’d be curious how you like yoursI have been using a Pferd (and a pair of calipers for measuring teeth) most of the time and a Granberg jig for overhauls.
Same here. Used a pure freehand file first and the roller guide helps to take away mistakes with one of the angles you need to maintain. Agree on the taker guide. I don't really like it and mostly file with guide off and only use it as to check.I am late to this thread but I use the Husqvarna roller filing guides. Not precision but I seem to get reasonable chain life.
DIY Chainsaw Sharpening - Roller File Guide and Depth Gauge Tool - Stihl Husqvarna Echo - YouTube
I agree with the video that the depth gauge part of the filing guide does not work well. I use something similar to the rig the guy on the video uses.
I'd like to give it try but no one has answered my question, how does the Pferd maintain the correct tooth cutting height if you use it on a chain where the rakers are high?This is why I love the 2in1 you are doing both as you file .![]()
You should clean the stone up with every chain. Maybe get away with a small, say up to 24” chain, if it’s just a touch up but if the next chain is a full grind then you should clean it before you start. Not sure the hardness of those stones. Usually the blue chisel bit stones are fairly hardI already ordered a 3/16" CBN wheel for my .375 and .404 chains, so the only dressing I will be doing is on the .325 and raker grinding wheels. I left it split like that so I could get a feel for both systems (and also I don't sharpen that much .325 chain and CBN wheels are expensive).
I haven't even bolted it down yet, but I have a frozen up old dirt-filled stumping chain that I'll be running through the ultrasonic cleaner and then learning to grind on (probably this weekend).
I don't think my learning curve will be too bad because I've been filing chains for a long time, and it looks less complicated than my old Granberg hand filing jig!
Also, this whole thread is moot because it turns out you can just put a rat tail file in a drill and take care of business. Who knew.
