How tall does the chimney need to be? What's wrong with the current setup? Can you post some pics? If you have some fairly accurate measurements, Sean at dynamitebuys can work you up a quote for Selkirk. He is very helpful, and thorough, and has several satisfied customers here.
The BK is likely the priciest stove you have listed, probably $3500ish, maybe a bit more. Fans are optional. Are they necessary? Maybe. You can always add them if you need to. I run mine when it's cold.
Not sure about the others, but the BK weighs in at 465lbs, according to specs. Not a heavyweight, by any means. It would be like me and my twin standing next to each other on the floor.
I would call it pretty much idiotproof. If you're chilly, give it a little more air. If you're too warm, turn the thermostat down a little. It responds quickly. It is very predictable, and I have never had a time when I thought it would run away and get too hot, even with high winds. You do have to clean the cat off now and then. I brush the front off with a soft paintbrush, and (carefully) suck it out with a shop vac, front and back, when I brush the chimney. Yes, you will have to replace it eventually. You have to decide if the ease of operation, and clean low burn capabilities, are worth it to you. I think the cat runs around $300.
That's my two cents on the stove. If you want to spend the coin, you won't be disappointed.
