precaud said:raybonz said:That may be true but I think the effect is neglible
100 lbs difference is unlikely to be negligible - that's 33% off the weight off the heavier one! Chances are, it's quite noticeable.
Methinks you are applying an "old-school" assumption that "heavier is better." I don't buy that, especially when it comes to efficient heat production. Too many other considerations weigh into the durability issue to say that weight is the dominant factor.however I feel durabilty would be the biggest trade off..
You will get a faster heatup with the thinner steel but it will also have less thermal mass so it will also cool down quicker.. Soapstone stoves are a good example of this plus you get more uniform heat from the larger/heavier heatmass.. This isn't gospel just my opinion.. Quality of construction along with good materials and design will dictate stove longevity (plus proper operation and maintenance)..
Ray
