J, turn off the feed valve from the boiler to the zone, for now. Atleast until you find the freeze up.
Ask me how I know this. The flood was epic![Mad :mad: :mad:](/talk/styles/default/xenforo/smileys/angry.gif)
Hehheh . . . "unthawed" or "thawed"?![]()
OK , mister English teacher. Thanks for the correction. Just like my wife.
I expected you to mention using a torch sometimes ends up with a visit form your guys.![]()
Didn't a member around here sell a little unit to attach to your boiler that would energize the circulator for a little while every x hours, to avoid freeze-up for woodburners?
Bridgerman . . . Bearmountaindesign.com . . . think that's the guy you're thinking about.
Around here they always called them "salamanders". Glad it all worked out.
I think the heat tape is a good idea. You might also look at sealing up any air infiltration points where outside air can draft on pipes.
Glad it worked out for you.
It may be overkill but you can also apply some thermostatically controlled heat tape to the pipes before installing the insulation. You don't even have to connect them to power at this point but can connect via an extension cord if you have problems in the future.
Just to be clear you wouldn't have to wrap pipes with tape. You just run it linearly along the length of the pipe under the insulation you're installing. The small amount of heat added by the tape would be held in by the insulation preventing freezing.I'm not going with the tape, too much pipe to cover.
With a thermostatic control set near freezing so that you're not wasting pump or fuel energy.or you could just put a little timer on your boiler to circulate for a couple minutes every few hours.
(If you've got plenty of water, and you know your drain won't build up with ice and freeze solid.)Leave the faucet drip slightly as a trickle. The dripping water will keep the water in the pipe from freezing.
I have salamander heater that uses propane under$150 at farm supply storeActually I want to know what I just used, I didn't look at the brand but he said it took kerosene or diesel fuel.
I gotta get me one, what are they called? I see a lot that are kerosene but not diesel.
+1Good idea, its not overkill at all - all the insulation in the world won't help those pipe since they never get any warm water circulating through them ever.
This is why I hate it when builders put mechanical systems in uninsulated vented attics and crawls. And outside walls too. If all system where build inside the thermal envelope of the building we would never have these problems!
yup: http://www.bearmountaindesign.com/
that is the one I was thinking of. Seems like the ultimate insurance, rather than guessing where to put tapes.
