Air is in the line going to the valve
Is there any tell tale issue since I'm seeing bubbles from valve to tank?
Which line do you see air in? Valve to tank or pump to valve?
Anybody know what release I need to open to bleed the air out? I've filled and re fitted the hoses hoping to fix the issue but need to know how to bleed the air now that I've refilled it there's lots of air in it.
Ok, i think i will remove that filter and just connect it directly, I did not inspect it much when changing out my hydro fluid. The splitter was noisy at the crankshaft but that was prior to me changing fluid. At that point i was seeing bubbles. Currently i believe i have fixed the bubble issue as I do not see anymore bubbles. I pulled the lovejoy cover and everything looks fine, very little slop and watching it run during operation there is no slipage. not sure where the spider would be, is that inside the lovejoy? I replaced fittings and filled with new fluid and the bubbles and crank shaft noise have gone away. the pump, cylinder, and engine are all original to this manufacturer. I got this from the owner who bought it knew. He has not changed anything out except fabricating some more girth into certain portions.You said that it sounds noisy at the crankshaft and pump.Look at the connector and see if it has the rubber spider in there,and make sure connector is not loose on either shafts of the engine or motor.You might also get rid of that filter at the control valve,that might be cutting the flow down.Most splitters have filters on the suction side before the pump.
Wait...so if you clean the filter, everything works as normal? It doesn't sound like you have a filter problem (sounds like it is doing what it is supposed to), it sounds like you have a contamination problem.he only thing i know is if i pull the filter and clean the crud out, the problem is remedied.
