Gonna try to tackle that before tonight's burn. I can feel the primary plate but can't see itHave you modified/improved the primary air intake yet?
If not, you may as well take a swing at that as well. Maybe?
It's not an airtight seal. If I hold a insence up underneath it some of the smoke is very slightly sucked in. Not all of it not even half. But some. By the way I called us stove co. And left them a message about this designIs the primary air closing 100% now or can some primary air still get through to maintain the air wash for the door glass?
It's hotter than hell in here lol. Stove top got to 888f in the Hotspot. Turned off all lights and it wasn't glowing but can definitely smell that hot stove smell. Last temp check she's down to 850 so slowly coming downWow this stove has a mind of its own. That thing would work great in my un insulated block house. I need those kind of temps to keep it comfortable.
Just realized this ir is only rated to 716f possible false readings? @mdocod cod I try to get the ir gun as close to the surface as I can to make that measuring ratio small. Is this wrong? @3650 do you think I'd be better to leave the dampers open? I'm more concerned about stove top temps than the flue temps even though those are high to
