iceman said:many might argue but with harman it is always better to run on stove mode......you can set your usage for temp etc.... room mode you cannot control when the sensor picks up any temp change it starts burning like mad to raise to what you have it set at... stove mode your room temp might go up or down but your usage will not change... its up to you to adjust according to what temp you want... i know in the winter i dont wanna use more than 1.5 bags a day so mine will get set to that on the coldest days..... sometimes i go to 2 bags aday (setting) for a short time (before bed and right when i get up) but that is only for 1-2 hours each way...
try setting the stove on 2.5 with a feed of 4-4.5 fan 3/4 try it see if it works and how far off from where you wanna be.... then go up .5 if you get over 3.5 turn your feed up... ideally you want the fire as close to the edge as possible without it shooting over burning pellets into the ash pan.....the closer to the edge the better the burn....but dont get burning pellets going over the edge .. if so the feed is to high
I W0NT THE PELLETS T0 BE CL0SE T0 THE EDGE 0F THE BURN P0T? THE FR0NT EDGE WHERE THE ASH FALLS 0FF? I TURN THE FEED WAY D0WN AND IT SILL KEEPS MY HOUSE AT 68. BUT USING AL0T 0F PELLETS. THE L0WER THE FEED LESS USE F PELLETS??
