I too been thinking of heating water as well. Nice idea using baseboard radiators
I was thinking about using automobile A/C condensers to capture the heat.
The Harman p68 sides and top are super hot! I have fans on both sides and above
blowing at a 45^ angle to move some heat away.
One thing that bugs me about the Harman P68 is the lack of a remote temp control.
There is only a temp dial on the control panel to set.
No good if you want a timer/setback thermostat.
I am gone 14hrs/day working so I lower the temp dial before I leave
and turn it up when I get home. But it takes hours to re-heat the house
and by that time, am already in bed fast asleep.
I'll be making a mod for the Harman P68 to use a dual temp thermostats so that
my home will be nice n toasty when I get home without burning fuel all day long.
There are a few ways I can do this as I know electronics, but it means I would
be voiding the warranty so am on hold before I start modifying the electronic
control board unless they give me approval (yea, right...).
I yet to take any readings even to get the parts needed.
A simple way (assuming one has a time-control thermostat) is to have the
remote thermostat to trigger a resistor across the control board's temp
potentiometer (pot).
I will need to take resistance readings on the current pot set at 75' to get the
base value so that by adding a resistor in parallel (through remote stat) to equal
the same value while pot is set at 60' in order to trick the board so that it thinks
its set at 75'.
(broken image removed)
Another way with more control is to get a 3 pole contact relay and have it totally
bypass the boards temp pot when remote stat timer kicks in.
Would require another potentiometer, but there cheap. Would also require cutting
the circuit boards contact tracers to the original pot.
The relay will be very small as there is no current to worry about.
I've already complained to Harman as it would of been simple & cheap for them
to include a remote stat control. They claim to be high-tech, but its not user friendly!
