Pellet jams
None with my Harmon XXV (New Last year Floor Model). Eats anything and everything. Even decomposed pellets.
I've had a cumberland stove for years, but in the last couple of years pellets have gotten longer causing bridges and pellet jams!
I get long ones, short one, and dust. All goes thru and make Flame and Heat just fine. Stove don't care what it eats as long as it's pellets. I get them from North Idaho Energy Logs. Oh they make Energy Logs too. I like how they wrap them. Double Wrapped and no wet pellets. Event those the stove ate last year. Got some other brand pellets. Not double wrapped
Reactions: tlc1976
Ok, ill ask. What brand pellets r u using? How long are they?
Do you have a bunch of them? You may want to get some shorter ones. If you have tons, maybe blend them with some shorter ones. I got into the habbit of only buying 5 bags of a brand to try before committing to pallets of one kind. Kinda backfired on me tho. Bought 5 bags of green supreme from lowes. Nice medium length. Then got 3ton of gs from Home Depot delivered and they are really short and meter too fast! Discovered this when i unwrapped my first skid here at home.
Same here. Knock on wood never a pellet jam so far. If it gets a long pellet it snaps it, I hear it do that every couple hours or so. I did shear 2 auger pins but that was within the same month and like 3 years ago. It pushes fines through no problem, never have had to clean out the auger. I've burned about 14 tons so far I think. Original bushings. Never any binds or squeals or anything.
The gal I knew in 2012 had a King stove burning Kirtland pellets. The auger started binding and squealing during the first ton and she had to open it up and clean it out. I burned probably 5 ton of the Kirtlands in mine and never had that problem, but that was like 4 years later so the formulation could have changed.
Never any jams in 27+ years? I see some as long as 1-1/2 maybe, maybe longer …. but stove eats them.
X2 but I have been burning pellets for 19 years
Reactions: Ssyko
