I decided to go with wood simply because I plan on scrounging and was afraid of pellet costs rising.
dsm1212 said:Ok, I guess it makes sense, but in practice this seems to ignore the amount of control you have with some of the fuel types. For example, I would think that the effect of a thermostat actually makes those btus be used more effectively. I'd argue the ability to deliver the heat when you need it has a big impact on overall efficiency of your house as a system.
Take an extreme example. Let's say we could get 100% efficiency from wood, but it would all erupt from the log in 1 second. The room would be very hot for a while, the house would leak energy faster (because of the higher differential inside vs out), and later when you needed warmth you'd have to burst another log. To maintain a minimum temp you'd have to keep the place much hotter than you like because you'd have no other means of control. If you could put a thermostat on the system which had enough control to keep the temp where you wanted it, the room would not be excessively warmed and the heat loss would be minimized from the house. In my mind, this gives an advantage to oil, gas, and pellets because they have much better control over heat production. I'm no expert and haven't thought about this before, just rambling.
Steve
Steve, you are not just rambling, and you're getting to the very essence of efficient combustion.dsm1212 said:Take an extreme example. Let's say we could get 100% efficiency from wood, but it would all erupt from the log in 1 second. The room would be very hot for a while, the house would leak energy faster (because of the higher differential inside vs out), and later when you needed warmth you'd have to burst another log. To maintain a minimum temp you'd have to keep the place much hotter than you like because you'd have no other means of control. If you could put a thermostat on the system which had enough control to keep the temp where you wanted it, the room would not be excessively warmed and the heat loss would be minimized from the house. In my mind, this gives an advantage to oil, gas, and pellets because they have much better control over heat production. I'm no expert and haven't thought about this before, just rambling.
Steve
.We use essential cookies to make this site work, and optional cookies to enhance your experience.
