Had pretty much settled on the Jotul, but after reading more in these forums I'm wondering about the PE. Both stoves are available fairly close by. Cost of Jotul is a shade over $1200. Here's the home info:
two story plus basement, ranch built in 66. Nothing but attic on upper floor and ceilings are insulated. Oil F/A furnace. Fireplace on inside wall with masonry chimney(that I will reline) Just remodeled two rooms into one so it's a 30x30 area that is fairly open. Floor insulated, new double pane windows and french door. 8 ft. ceiling and no ceiling fan. Not really trying to get heat into bedrooms down hallway(but won't be sad for any heat that drifts that way.) Want to heat 24/7 and use oil for backup as much as possible. Let's see, what am I forgetting??
Pretty set on the Jotul, thanks to advise from Be Green and others(although I might have given a smaller sq footage in my original question - so hope the 3 CB still adequate.) My question: what might I gain with the PE Vista instead of the Jotul? ie longer burn time, better technology, a red (ok, maroon) stove. I've read the other posts and hope to hear especially from Newtofire and Roospike, as well as any others who want to weigh in. Thanks
PS: Hope this isn't a controversial topic(here is where I would put a smiley - but last time I tried I found the smiley's and lost my post. And I thought I knew more about computers than wood stoves!)
in whorehouse red
