iceguy4
I thought you were running it in the manual mode this time of year
Yes since this fall , after having problems with it "lighting" (I caught it...pellets in ashpan) I decided to hook up a good "dump zone" (basement zone) . This I did with a relay hooked to the blue over heat wire ...then I piggybacked it on to thermostat wire so both can operate that zone. then I keep that thermostat set low so there is a reservoir of cold water to cool the boiler off. Even with the DEEP setback zones ...it hasn't overheated and shut off. I suspect spring and fall I will want to switch to auto.
Update 1//12/14
Over 8 1/2 tons through new burnpot. Did a thorough cleaning of the burn pot...Looks perfect... I'm kinda woundering if its because I'm running in manual.
![hmm ;hm ;hm](/talk/styles/default/xenforo/smileys/hmm.gif)
![shuteye <> <>](/talk/styles/default/xenforo/smileys/shuteye.gif)
