You would only use the ceramic insulator if you were using a pressure ignition system. As you are still using the fin igniter you can disregard the ceramic insulator.
I'm maybe 4 tons through mine...you? Also I got a call today from ed...he was checking up on itSame here! Just cleaned her out last nite and pot looks the same as when I installed it.
Didn't want to start a new thread...just checked my new burnpot....its puuurrrrrrfect. I have been running it hard in manual![]()
I'm possibly switching over to a PB105 since I've realized that the PB60 is too small to heat my home. I have an oil boiler backup in place now but would like to know some of the pro's and con's on the PB105. Any info is greatly appreciated.
I believe it is fixed. My new one has close to 7 tons put through it...looks like new. I too LOVE my boiler and its looking like it will save me close to $3000.00 .....just this seasonNow that the burnpot issue appears to be solved, I don't think you can go wrong with it. It is a good, medium priced, easy to clean and fairly simple boiler that has cut my heating and domestic water bills in half. I am 100% pleased with it. Good luck.
I have run over 5 tons through my new style burnpot. Just did cleaning today and it still looks in good shape. I am still waiting to see how it performs this spring when the boiler will start cycling on and off again.
This time of year, yes. Between the in-floor heat, forced air heat, and DHW; the unit very seldom idles. I have three in-floor zones that run off of one heat exchange system. It is a poor setup, that I didn't know any better about when we built the house, compliments of our heating contractor. It should have been 3 separate setups. I have a PLC that I control the 3 zones with to make sure that no more than one zone will be heating even if all 3 are calling for heat at the same time. The three zones are floor heating in the master bathroom, in-floor heat for the basement (75% of basement is finished off), and in-floor heat in the garage. If the garage were to run while one of the others were on, this would actually cool down the other one as the garage is only kept at 45* and the return temperatures are very low.
Yes...but you better have a dump zone or it will overheat and shut off. In another thread I posted observations... yesterday my stove at idle ...auger on 3 seconds ...off 15 seconds ...when ramped up ...off 3 and on 14 seconds...So in the manual mode it would keep a small fire in the burnpot until the thermostat called for heat? Then the fire would come up to satisfy the thermostat then return to a low fire?
I have the unit in Auto mode.
I believe that if you had the unit in manual mode, it would operate just as you say. A person would have to make sure to have a dump zone if you ran in manual mode to make sure unit would not overheat.
Iceguy4 beat me to it.
