Palazzetti Prima Pellet stove is awesome!
Hi Tay,
I purchased a motor assy. for an Amercan stove and transferred the motor, end plate and bushings to the Palazzetti wheel and blower housing. This motor is readily available at local stove shops and turns at the same RPM . Click links,
(broken link removed to http://www.ebay.com/itm/Fireplace-Blower-FK4-GFK4-FK12-FK24-HB-RB64-for-Monessen-Vermont-Majestic-/331037131453)
http://www.amazon.com/GFK4-Replacement-Fireplace-Monessen-Castings/dp/B00DY1KJO4
Thanks Phil, so the motors in the links has our PALAZZITTI variable 5 speed and will attach to housing and bushing the same?, cool. Thanks again Phil.
Tay,
All permagnet motors function the same. The control and main board vary the voltage to the motor for all 5 speeds. If you look at your stoves blower, you can see the motor sag due to weak mounting point. this caused the bushing failure. I transferred from the FK24 blower, the motor and end mounting plate along with the bushings to the Palazzetti blower wheel and housing assy. If you are handy with tools, it's self explanatory. I still suggest buying a new Palazzetti blower and use the repaired one as a back up. Call the distributer if Karen doesn't have the blower. How many hours are on your stove??
