The question as posed is whether it's safe to run the stove with a large unregulated hole open to outside air in the back of the firebox. That is what would happen without the baffle in place.
With all due respect, that's an awful big if, and any other potential damages are still unknown. I stand by my earlier recommendation to find a quality replacement stove. It's just too damned important to play if's on this situation. I also stand by my earlier recommendation to call The Chimney Sweep and talk to Tom personally. He truly will help the best he can, and he's been in the biz for decades and is intimately familiar with this stove and others. I also still recommend looking at the Drolet, Englander, or other quality, but inexpensive replacement.if the damage is just the baffle then only performance will suffer and it would be safe to use. I
@LouCammie, what is your situation, re: chimney. Do you have chimney and stovepipe ready to safely connect a stove, whether this or another? Do you have a hearth ready upon which to sit this stove?
Also, what is your firewood situation?
We need to find the cheapest safe way to get heat running in your house, now. That may or may not involve this stove.
That's terrible. Hope you are on the mend and someone will give you the help you seek.Been very sick with pnumonia-had 8 appts for chimney guys-no one has ever showed up
well I'm back here after a lengthy illness and a month later and still no luck finding a chimney installer-8 no shows last week. I don't know what ever happened to a healthy work ethic. I just do not know what to do anymore. The pneumonia was a direct result of living here.@LouCammie, what is your situation, re: chimney. Do you have chimney and stovepipe ready to safely connect a stove, whether this or another? Do you have a hearth ready upon which to sit this stove?
She previously said they are using electric blankets and electric space heaters.And out of curiosity, what did you use for heat before?
At this point I can certainly believe her story. I've been trying to contact one of the local churches there that just happens to be affiliated to the same organization our church is, ZERO FREAKIN' RESPONSE for 30 days now! And Facebook notes that they have indeed seen the messages I've sent to them. Not even a follow up "don't bother us". Seems these people in Newfoundland Canada don't have much time for anything but themselves.
Maybe it just slipped through the cracks![]()
I will try reaching out to some canadian sweeps and see if they know anyone nearbyIf anyone has any strings they can pull, in terms of getting the chimney situation evaluated and resolved, it would be much-appreciated. We already have a solution for the stove, but if you’d like to help out with that, please PM me or begreen. The primary obstacle for now is providing a safe installation.
That sure sounds expensiveIt's a tall 3 story liner in a fireplace, complicated by the fact that the chimney was cut off below the roof, so it will need a class A extension attached to the liner and chimney stub.
Where did you come across this info? I thought she had resolved her issues since we hadn't had any follow-up posts. Can one assume you have contact information for her should I actually get through to someone??It's a tall 3 story liner in a fireplace, complicated by the fact that the chimney was cut off below the roof, so it will need a class A extension attached to the liner and chimney stub.
Issue not resolved. There have been a few setbacks and other complicating factors. Please contact me or begreen if you are able to help, we have her contact info, but won’t be sharing that without permission and reason.Where did you come across this info? I thought she had resolved her issues since we hadn't had any follow-up posts. Can one assume you have contact information for her should I actually get through to someone??
