Pacific Energy Alderlea T5 insert door gasket replacement
cbscout
118
Mid-Michigan
I may need a new door gasket soon for my PE Alderlea T5 insert. It seems that I've been replacing it every couple years. I asked my dealer why they need to keep replacing it, and he just shook his head and said "I don't know." Next time I'll replace it myself, since it costs a good bit for each replacement Does anyone have any thoughts as to why the door gasket might be wearing out so soon as to need replacement every 2 years?
Thanks!
Confirm that the factory (oem) gasket is being installed.
Good point. Even though it's a PE dealer I don't know that they are installing the OEM gasket. I'm replacing the glass gasket, and I found and ordered the OEM gasket myself. I did see that if I wanted to buy the OEM door gasket from them, though that I had to pick it up onsite according to PE requirements. Not sure why it didn't extend to the glass gasket.
Reactions: moresnow
I tried getting an OEM door gasket from the PE dealer in Seattle and they sold me a substitute off of a reel. It sucked. The factory gasket should last 4-5 yrs with regular use.
Reactions: cbscout
Part numbers…
  • [Hearth.com] Pacific Energy Alderlea T5 insert door gasket replacement
Reactions: cbscout
Yeah, I'm thinking that is what might be happening with mine. But even the factory one only lasted the first 3 years according to the dealer (they clean my chimney every year and inspect it the insert).
Glass gasket is a Canadian page.
Reactions: cbscout
Thanks for the links!
Is it necessary to have a joining strip with this gasket? I got the one linked above from stove parts 4 less, gasket looks the same but no joining strip. The current one on my stove does have that strip.
Reactions: cbscout
I have never used a joining strip, just a dab of RTV on the ends where they meet.
That's a good question, I didn't think about that. I'll be doing my door gasket at some point (just did the glass gasket) and this is good info to know.
Reactions: Woody5506
I am tired of my gasket leaking where they made the factory joint. P43 main gasket.
Leaked from the very start. They used some sort of heat shrink so the steel is in contact with this wrap instead of gasket. I bought new gasket. I will do as you do and RTV the ends. Question. Should I RTV the ends as soon as I make the cuts? I have a feeling the ends fray after they are cut. Should I dry run the install and determine the length, then cut and seal the ends, then install later with a bit more rtv? I want 99.9% gasket and get rid of the leak.
Reactions: cbscout
Clean the gasket channel first. For length, I dry fit first and cut it a tad long. The fit should be relaxed, not stretched or pooched up. Then trim to an exact fit plus 1/4". A sharp set of shears help minimize fraying. The apply the RTV to the gasket channel and set the gasket. Not too much, but enough to bed the gasket in. Just before finishing, dab a little RTV on the gasket ends and set so that the two ends contact each other. After setting the gasket, I hang some newspaper over the door opening and then close the door on the paper. This is in case there is ooze so that it doesn't stick to the stove body.
Ok thanks. I bought the cement at the same time. Should I use the cement since I have it? I was thinking I could make a perfect cut on the bench, and then seal that end with RTV. Maybe a quarter of an inch. That stuff dries fast. Then, dry fit it in a relaxed fashion, find the cut point, then cut on the bench and repeat. Then use my cement, and a final dab to seal the two ends together. I was going to do this all with the door off. Or should I be ready to close it with news paper to seat it before the cement/or rtv sets?
This will be my first door gasket change since i got got the stove at the tail end of 2016. I did the dollar bill test a couple days ago and everything seems fine. Time would tell however that it really should just get done. Near the latch the gasket is compacted some but not falling apart or fraying much anywhere. Part of me would rather leave it, but this will be the 2nd season of me saying "it's time!". Stove still throttles down just fine although I feel like the flames do dance a bit quicker than when the stove was new , meaning it's maybe not throttling down quite as much as it should if that gasket isn't sealing as well as it should. All last year I still got great overnight burn times, maybe this year they'll be even better after replacing.
The main complaint I have is the stove is brand newish, and I have a smoke trail on my glass where it is sucking air across the poor seal which is about 1.5". I tried adding an RTV layer and it didn't work perfectly. I bought some graphite fiberglass gasket and figure I can only make it worse....however, maybe perfect??
If you want to test your gasket, use the smoke test while it's running. I already know mine leaks and where.
