Assuming an unpressurized storage tank has a tight fitting cover and does not need to continually be "topped off," will the ogygen level in the water eventually be reduced to a level comparable to a closed system?
Fred61 said:Assuming an unpressurized storage tank has a tight fitting cover and does not need to continually be "topped off," will the ogygen level in the water eventually be reduced to a level comparable to a closed system?
Fred61 said:Thanks guys! I wasn't thinking about the expansion and contraction of the water. I guess you could say that the tank is breathing as the heating and cooling takes place by exhausting upon heating and inhaling upon cooling. If the cover was tight enough it would be like a canning jar and collapse the tank or cover upon cooling.
slowzuki said:BTW Hot water holds less oxygen than cold water.
Tom in Maine said:I would be a little skeptical of permeation of any material except metal. A condom or any polymer might allow enough O2 permeation to be an issue. A metal "condom" probably would be okay.
Boy, there's a mental picture!
A test will ultimately show the answer, for the tank, that is!
Does anyone know the details of the engineering and assembly of the huge vertically-expanding metal natural gas tanks like you see just south of Newark NJ if you go down the Jersey Turnpike (or was it the Garden State Parkway?) They have telescoping metal shells with cages around the sides to keep them straight and reinforced. They change dramatically in overall height depending on supply vs demand. I always wondered whether they had a bladder inside or, if not, how they kept the gas inside. Whatever it is, if it were feasible, it seems like it might be adaptable to water storage- and maybe in a simpler way, as the degree of expansion is less.
