Hello, well it was in the upper 40's lower 50's today so want to see how the 13-nc would do. Well It started just fine I was trying a top down burn for the first time. I was getting a stove top temp of 550 and a flue temp of 200 to 300 max. There seems to be a good secondary burn and very little smoke from the chimney once it got going good. When the temp is colder outside will I get a better draft and a hotter flue and chimney temp? Or is it OK on the newer stoves to have a lower flue temp as long as not getting much smoke. I did get a moisture meter and the wood was showing 19%. Thanks for the help just trying to get used to the new stove. I was used to all the smoke and creosote that I used to get.
Don
Don
