MSG - way to take the initiative in directly contacting the manufacturers!
Tom- this is DIRECTLY opposed to what you have stated. Someone on one side of this debate is ill-informed. Let's find out who!
Are there really "many documented cases involving house fires due to out side air kits backdrafting" as stated directly from the tech at Jotul? How are we going to locate these documented cases? Are they just urban ledgend? Has the Canadian government also been duped somehow (their "residential guide to wood burning" document that I previously linked to in this thread says "The same research shows that wind effects around the house can reverse the flow in these ducts, which may create a fire hazard if the duct is connected directly to the combustion chamber").
And what about Jotul's comments that "the scientific data done by the R&D department shows that there is little to no improvement on overall efficiency or performance" which is also basically what is stated in the Canadian document.
I think the Jotul guy had a great answer for why all the stoves have the OA adapters and kits - politicians basically FORCED them into it! And in all fairness, I'm sure the politicians thought they were doing the right thing but at least if you believe these references to research and documented problems, it turns out to not be such a good idea.
I know we are going to get to the bottom of this!
MountainStoveGuy said:The first thing i did today was call jotul and hearthstone. I havent talked to hearthstone, but i have talked to Jotul. Here is Jotuls position on the issue. Im quoting Mike in the tech department. "there potentially dangerous, there has been many documented cases involving house fires due to out side air kits backdrafting" "the scientific data done by the R&D department shows that there is little to no improvement on overall efficiency or performance" then i asked, then why do you sale them? There responce, "we as a manufacture are boxed in a corner, washington state required them and we dont want to miss market share" "when dealers or customers call here, we absolutly do not recommend them"
I will keep you posted on hearthstones responce.
Ryan
Elk if you have time, can you call VC? or any VC dealer out there, can you get there opinion?
