What is going to seal the front or will the block off plate be attached above the missing bricks? Are there any screws holding this piping together?
Hi,
I cut out a hole in the roxul insulation and have put it above the blockoff plate. See photos. The roxul you see above blockoff plate is bat #9. I got 8 bats stuffed above it. The 10th bat will be wrapped around the back and sides of the insert.
Once I push the insert back in and wrestle the elbow into the top of the insert, I will be using masonry screws to hold the blockoff plate in place.
I will then install the missing bricks in the front to seal the blockoff's front side. This has to be the last step because I can't get the insert back in without having the gap provided by the missing bricks. Due to the angle of the insert and elbow, I have to slide the insert in and then lift up the front of it in order to get the elbow to slide in. Really sucks that way. I wish I could find a flexible 2' liner so I wouldn't have to use the rigid elbow.
Know of where I can get one? All the flexible ones are ~20 feet long. I only need a couple feet.
cheers
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/111/111068-a4d97b5f8bb077a82dec27484ad2cb1c.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/111/111069-ad063b68b4bbc7cea6951496a3d6e273.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/111/111070-014a3c6a02d85a02cfb4bbdeccdacd8e.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/111/111071-f72240ff89d34357a180994ef439857c.jpg)
