Hello stove gurus,
I have read hundreds of posts on this site and can’t figure out the problem I’ve been facing.
I hope you can solve the mystery of why my Osburn 1600 wood stove insert barely heats a 12 foot by 12 foot room.
All photos are at bottom.
We’re desperate for a solution. Whomever solves the problem will be the recipient of an Interac payment of $50 for my gratitude and a photo of my happy family cuddled around a roaring woodstove.
OSBURN 1600
· Model Number: OB01601
· 65,000 BTU/h.
· Dimensions: 24.12''W x 21.5''H x 22''D
· Heating capacity: 500 to 1,800 sq.ft.
· Firebox volume: 1,85 pi.cu.
· Maximum log length: 17"
· 130 CFM blower (works fine)
HISTORY of PROBLEM
The Osburn 1600 (see photo #1) came with the house (built 1978, 2,000 sqf, split entry) I bought in 2009. It is installed in the fireplace (an exterior chimney – see photo #2) in our basement family room. The stainless steel liner is not insulated. It runs in a clay liner. From the top of the stove to the liner cap (see photo #3), the length is about 25 feet.
The basement family room is fully finished. I took the walls down to the studs and had a red seal drywaller redo the insulation, including vapor barrier. He even used the formed plastic membrane around the electrical plug in boxes.
He re-insulated most of the walls in my house. Also, I had all new windows (very high ratings) put in. So, overall, the house is very well insulated now.
Weather: In winter, the temperature averages 20F. All in all, the winters here are pretty nice here in Nova Scotia, Canada.
Winter 2009: The room was often too hot to be in. It heated much of the house. The room’s thermostat usually showed 90F.
Winter 2010: Same as Winter 2009
Summer 2011: I had a chimney cleaner come in. He swept the chimney and then came in to clean out the stove. When he removed the baffles and unscrewed the insert’s exhaust collar, he could feel that the exhaust collar was not connected to the liner. We removed the insert and saw that the collar had rusted away. See photos #4 and #5. Talk about a fire/gas hazard. No wonder I was getting such awesome heat; most of the heat was coming straight back into the room rather than going up the liner to the outside.
We installed a stainless steel elbow. We then pushed the insert back in and connected the collar to the elbow.
Some of the firebricks were cracked, so I replaced them all with similar size ones from Home Dept (I shaped them with my grinder). I also used the firebricks for the baffles. Not a perfect fit, but pretty good.
Winter 2011: I ordered cords from 2 different suppliers. I even burned cut-up wood pallets that were very dry. Nothing helped.
The room was somewhat comfortable to be in. However, the Osburn heated only that 12’x12’room, averaging only 66F--even with 2 eco fans spinning away. I have a fully furnished (and newly insulated) office that is 6 feet away from the Osburn. I keep the door open. Even with the insert running full tilt all day, when in the office, I still have to either put a blanket over my lap or turn on a space heater.
When I have the woodstove fully roaring, the most the room will ever get up to is 77 degrees—that’s when it’s not very cold out and the stove has been roaring for e.g. 12 hours with multiple loads. The rest of the house is still too cold so we have to turn up the oil furnace and wear sweaters and wool socks.
Summer 2012: Thinking it must have been bad wood every time, I bought 2 full cords off of the most famous/reputable firewood distributor. The company has an A+ rating with The Better Business Bureau. It cost a premium and I could tell the wood was far superior to what I had been using previously.
Winter 2012: Same as Winter 2011. The expensive wood didn’t help at all. I even burned left over wood from the previous year. That didn’t increase the heat either. I had the insert inspected by a WETT certified inspector. He said everything looks fine. He agreed the firewood distributor I bought off of is the best. I even burned new, dry, clean lumber to test it. He could not figure out why the insert was not blasting out heat, heating most of the house.
I stuffed a lot of insulation behind and around the insert and as far up as I could reach. I only got an extra 1F in temperature.
NOTES
· The house is not airtight, so the insert should be drawing.
· The blower is functional. It has a high and low setting.
· I don't have a block-off plate
· I don't have an insulated SS liner (but I have stuffed as much insulation as I can around the insert and SS elbow)
· I do not have a thermometer to test the temperature.
· I do not have a hydrometer to test the moisture of wood.
· I put in a new gasket
· The stove did not come with the Baffle Insulation Weight. I only discovered this summer (2013) that it is a part that came with it originally. Does it make a difference? If so, I will order it.
· I don’t have a layer of insulation resting on the baffles.
· Even though I formed the fire bricks with my grinder, there are a couple gaps of maybe 1 square inch. Would that be enough to cause low heat?
· I leave a couple inches of ash
· Often I don’t see any smoke, which should mean it’s burning well, right?
· Once I get a roaring fire going, I wait several minutes and then leave the insert’s door open about 3 inches. If I don’t, it will become a weak fire, even with the air supply full open, ½ open, or almost closed.
· The room gets a few degrees warmer when I leave the insert door totally open. Not ideal, obviously.
· I’ve put the wood NS, EW, tipi, log cabin, huddled. They all seem to be the same result
· I use paper and bark to start the fire with small split wood. It can be challenging to get it lit.
· Once it’s burning fast, I put on larger splits.
· I rarely ever see secondary combustion
SUMMARY
When the stove collar was not connected to the liner because the elbow had rusted through, I had fantastic heat. It was also dangerous. I can’t afford to buy a few cords this winter but still have to use a heck of a lot of oil to make up for the low heat the Osburn is putting out. I am so frustrated that I’m tempted to poke some holes in the bottom of the elbow.
If anyone could provide suggestions/diagnosis, I would be extremely grateful.
Cheers and thanks!
OSBURN 1600
· 65,000 BTU/h.
HISTORY of PROBLEM
NOTES
SUMMARY
Cheers and thanks!
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/108/108576-7200a93df71e456e471c13c5bce52df0.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/108/108577-78494333602c087813c2b47836ed72dc.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/108/108578-9a74dfcb5f1e2c021ebae2264a99d110.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/108/108580-697af8d4d6da994f4374c8cf3902566d.jpg)
![Osburn 1600 insert not pumping out much heat Osburn 1600 insert not pumping out much heat](https://www.hearth.com/talk/data/attachments/108/108581-b4f5bd4ff30262dd83ea090c7b78d155.jpg)
