precaud said:I'm going to join you out on that limb, BG, and point out that, in use, the Castine is a completely different animal than the F100. If you're burning 24/7 then I'd say it would be fine. But if you're starting fires from scratch daily, as many of us do who use smaller stoves, the Castine is going to feel like a PITA real quick. You'll be using 2-3 times as much kindling and smaller splits to get fires started.
What bothers me about recommending such a larger stove is that he says the F100 is heating his space just fine, and his complaints are more in the nature of user-friendliness than heating performance. A north-south burning arrangement more accurately solves his complaints than a simply larger stove does.
There are many problems that he's trying to solve. Longer burn times, space constraints, aethetics, quality, etc. Almost any stove is a compromise in some degree or another. But it seems like the Castine would be a good fit here.
I'm not following your concerns Precaud. I don't use any more kindling to start the Castine than I did the 602. And I uses the same sized smaller splits to get the fire going that I used in the 602. Agreed this is a different method of burning as compared to the cigar box and it will take about 10-15 min longer to start throwing off heat than the 602, but the stove also retains and gives off heat after the fire has died down better than the 602. My point is that the Castine is a really flexible stove with regard to shoulder season heating. We live in a much gentler climate, but spring/fall can be longer. We are often heating from Sept to May, but are really just taking the chill off now. So far the Castine is working very well in that regard. And when a long burn is needed and the temps are low, the reserves are there.
But perhaps the Intrepid will be totally sufficient. Devellone - Where are you located? How many sq ft is the house and how well insulated?
