I've got this 2400 lb. green beast (Greenwood 100) sitting in my driveway about to be installed...or at least put in place under a roof.  So I'm talking to "certified" installers right?  The first one says that because of over-boiling during loss of AC power, he'd never install anything but an open system with a gravity feed tank above the boiler; no AC power needed to insure that an over-boil is contained.  Without it says he, the boiler will generate steam and melt down everything from the pex to the circulator impeller.  It won't happen often, but it only takes one time to shut you down and cause 1000's of $ worth of damage.  "Why not an AC power backup?", I ask and he says they may work most of the time but eventually the backup won't be there.
The second guy says, a battery and inverter is fine and that he'd never install anything but a closed system because having it pressurized allows higher operating temperatures, greater efficiency, and most of all longer term boiler life because of lower disolved oxygen (less corrosion) due to less make up water and no exposure to the air.
Me, I'm just shaking my head and going crazy here. It seems the open system is a better no-moving-or-powered-parts answer to thermal spikes whether arising from loss of AC power or just the normal cycling of the boiler. But then I don't want to be dealing with a pile of rust in 5 years either.
I need some collective wisdom on this (but if that's not available I'd love to hear from you anyway)!!
