Intake or exhaust?My stove turned out to be a blockage in the rear of the stove, blew it out with a wet vac and it's 100% .
You have a blockage in your stove exhaust is not coming out you got plenty air from your motor exhausted and going out you got a blockage if you blow out your stove it'll workIntake or exhaust?
My stove is when exact same thing start up it was fine because it start up it use a lot AirYou have a blockage in your stove exhaust is not coming out you got plenty air from your motor exhausted and going out you got a blockage if you blow out your stove it'll work
Watta mean??Oh gracious....sniffing to much stove paint I see
Damn talk texting , when it starts up it uses less air then when it goes through the motions the exhaust can't get outMy stove is when exact same thing start up it was fine because it start up it use a lot Air
What is this threshold blower assembly you are talking about? Do you just mean the Combustion Fan it's self?I dealt with a similar problem last year on the same model stove, turned out to be a failing hall sensor on the combustion blower. Gotta replace threshold blower assembly fer that ones do it pricey.
I have blown my stove out 3 X within 2 weeks using the leave blower on suction. I have completely dissembled and CLEANED CLEANED CLEANED. All the fans, the air sensor, the ports all the holes the exhaust pipe. Installed an OAK. Removed the back plates in fire box cleaned all back there. That stove hates me. LOL Replaced the main board, replaced the air sensor. replaced the combustion fan, ok i know a lot of money spent but like I said earlier I do like the stove and plan to keep and use it for years so the money is not all wasted and I have replacement parts now right Nothing changed.After start up Horrible tall lazy sooty flame with eventual pellet pile up.
I found a work around that I am using now. Put a fan behind stove redirected OAK from outside air to air blown into tube from fan. This works quite well. Still not perfect but no more lazy sooty flame. No more pellet pile ups only thing I can see now is the flame is dark orange when it should be a brighter color right? I know it is not a permanent solution but danged if I can figure out what to do next. Actually I do have gasket material on order from car masters and will replace the large gaskets under the backing plates. That's it I am stuck and now that I have a work around it is not a pressing major priority. Although I surely do want to master this Austroflamm and get it fixed right!
I absolutely appreciate every thought, idea, and answer on this thread. Any ideas about why that work-around works? what would make that work? The fan is just directed at the tube not forced into it or anything. I put a medium paper cup on the end of tube to gather a bit more air but it still is just setting in front of fan.
The only time I believe I hear any change in the combustion fan is when I restart the stove. It seems to speed up then or at least the air speeds up and makes a nice FAST short bright flame. I have not stood right there and observed the fan to see if it speeds up and slows down. When ever I do look it looks the same speed every time. Soon as start up is over I do not ever hear any change in fan. I also believe yes I have cleaned that stove top to bottom multiple times. I do not know where a blockage could possibly be that I have not poked, prodded, vacuumed, blown, brushed out or used the leaf blower trick on. All gaskets seem tight and fine dollar bill trick on door too. No clinkers or at least very little. If I do not use my "forced air induction" work around the fire pot will pile up pellets.
The broken wire you are wondering about in hall sensor circuit between the fan and the control board must not be on the combustion fan wiring right? Because with a new combustion fan installed that would have taken care of that. So where would I check for that broken wire?
I just received my roll of ceramic 1/8" sheet from McMasters. do you double it or just go single layer?
1992 Austroflamm Integra.........Today I meticulously cleaned the pellet stove AGAIN! took out backing plates vacuumed brushed everywhere in there. New gasket on lower plate. I had just cleaned the motors a couple weeks go so did not do them this time. Scrubbed the heat tubes with a brush and vacuum then used a tooth brush for more thorough cleaning. Used a coat hanger to get at the square holes behind the tubes all of them. Vacuumed the round tube that leads to the square holes used flash light to check them...clean.. Brushed out vent pipe then decided to change it by removing the 5' horizontal length replaced it with 3' from back of stove to end cap. Did leaf blower trick. not much came out but let it run for a good 3 mins anyway. Nothing changed flame still lazy and too tall.
1. replaced main board (joe)
2. replaced air sensor
3. replaced both snap disks
4. replaced combustion motor & gasket (jason)
5. replaced backing plate gasket
6. air pot full clockwise pellet rate full counter clockwise
7. installed oak or no oak makes no difference
8. cleaned that saustoflamm way too often the foxfire upstairs is a way better running stove
Austroflamm has very nice short active flame during start up cycle, soon as it hits the 15 (approx) minute mark it goes Lazy Tall sooty. This is getting to be a fight now between me and that stove I will get the better of it and WIN lol I swear I will.
Below is a photo of the flame at about 20 minutes after starting it will stay that way the whole time stove is burning. Never gets any better well that is unless I turn it off and do the start up cycle again then its great for about 15 mins.
Whats left? Hall sensor? what is it? Where is it should I change it?
I don't think 1.1 would be a problem, I think that is what was supplied from the factory. 2:1 could be bad and I know some stoves use 2:1 on their auger motors. St. Croix and Englander come to mind.FWIW When I replaced my auger motor I put in a 1.1 RPM although I can see where a 2rpm would not be good.
