I've lurked on the Hearth/Solar sections of this forum and found the information to be very helpful, but may have blundered into a problem with my own conventional system that you guys might help extricate myself from.
My house in central CT has an early 30's oil fired gravity fed boiler (fmr coal) which for the most part, performs fairly well. We really like the iron radiators!
However, on a recent kitchen remodeling - on the advice of our plumber we had the 2 under cabinet iron radiators replaced with hot water kick heaters. Unfortunately, these heaters don't seem to "kick in" ie the blower motors won't engage until the water temps hit 130-140 F. The plumber said that it was probably because the boiler water temps were so low due to the recent warm spell we were experiencing. However we recently had 2 consecutive mornings in the high 20's and with the thermo set to 68 F the furnace ran for the better part of 2 days w/o triggering the kick heater blowers. I used an infrared gauge that I use for tire/rotor temps on the track and the steel pipes leading into the toe kick feeds were indicating 110 after running the furnace for about 6 hrs (outside temp 45 - inside 75).
I guess my question is: what water temperature should I expect from a pipe that is roughly 20-30 feet away from a typical gravity fed boiler of that era?
Sorry for the long post, thanks
