Ashful
Okay, I'm confused by this:I'm a bit late to this thread but I installed a Geyser HPWH 3 years ago now.
Pictures are in: https://www.hearth.com/talk/threads/ducting-and-geyser.108580/
Saved 1 gall of oil per day.
The most pleasant surprise was the drop in AC costs in summer.
The oil DHWH is inside the air conditioned volume of our house and so the AC had to shift the waste heat from the oil burner as well as the general house heat.
In our case, when all done, we got summer DHW for just about free and in the shoulder seasons, a barely changed overall electric bill.
So, you installed in parallel, and I'll assume the reason is so that you can throw a pair of valves and run off either oil (winter) or HPWH (summer). However, why wouldn't you just plumb them in series, with the HPWH up-stream of the storage for the indirect oil? As already mentioned here, the oil indirect would be reduced to just maintaining the water coming off the HPWH in summer, and could be set a little lower than the HPWH, so it cycles only under extremely long storage situations. It would give you significantly more storage, and rather than switching valves twice a year, you could just kill the breaker to the HPWH in winter.This shows how the Geyser was plumbed in parallel with the 80 gall oil water heater.
What did I miss?
