Non EPA vs EPA
Yamaha_gurl said:
Hey all,
I want something that will give longer burn times, EPA approved, for under 1500 sq feet and is available in Canada, Ontario to be specific, and that is under $1500....is this do-able?
Thanks all :D
$1100.00 at Home Hardware gets you this:
(broken link removed to http://homehardware.ca/Products/index/show/product/I5531418/name/stove_wood_epa_nxti)
http://www.flame-intl.com/product.aspx?CategoId=1&Id=394
.....And check Rona for these:
(broken link removed to http://www.drolet.ca/product.aspx?CategoId=1&Id=212)
I think these are the ones they sell for about a grand.
.....And these go for about $1500.00
(broken link removed to http://homehardware.ca/Products/index/show/product/I5530945/name/stove_wood_epa_ht2000)
(broken link removed to http://www.drolet.ca/product.aspx?CategoId=1&Id=208)
You MIGHT be able to get a Pacific Energy Super 27 with pedestal and black door for not too much more than $1500.00
(broken link removed to http://pacificenergy.net/product_super27.php)
Should be a dealer not too far from you.
CZARCAR said:
Bigg_Redd said:
Yamaha_gurl said:
Hey all,
Well it's getting slow here on the hearth forums, so figure I'll start posting my questions away.
First year burner here, bought a 1980 Fisher Honey Bear wood stove and have been burning since October. Currently we get about 3 hour burn times ( I think burn time means time between getting a good fire going to having enough to start another cycle, right?) and it sucks, I mean...the thing gives off tons of heat, but we load it all the time. Therefore, I'm starting to think about next year. I want something that will give longer burn times, EPA approved, for under 1500 sq feet and is available in Canada, Ontario to be specific, and that is under $1500....is this do-able?
Also, is there really a BIG difference in firewood consumption from non epa to epa? Anyone care to share their experiences?
Thanks all :D
STOP!
3 hour burn times? Even with a pre-EPA stove like a Fisher you should be getting at least double that. Your Fisher has an air leak and it's probably traceable to a faulty or non-existent door gasket.
duh,she lives in canada, not washington & guess what= cold exterior eats up wood via draft.
Fishers are built pretty tight. There's got to be extra air for that draft to over draft. I'm guessing gaskets. Bet me.
Bigg_Redd said:
CZARCAR said:
Bigg_Redd said:
Yamaha_gurl said:
Hey all,
Thanks all :D
STOP!
From this picture that I found of her stove, it looks like it is like mine and does not have a gasket. A good many fishers did not use any rope style gaskets.
[Hearth.com] Non EPA vs EPA
It has the gasket in the door. I know you posted a four hour burn time Penn....I swear it's on here! :D
For a day burn most likely I was talking! My burn times have gotten much easier to increase now that I have the baffle. But even before, I could do an all night burn. It just wasn't as consistent or easy and I had to use a chimney damper. Now I don't need to use the damper.
pen
