1kzwoman
Try building your fire with shamefully small splits (dry) then add larger as (if) you get a fire to burn
Grisu, at that point I believe there was a 10" 2"x4", 2 10" 1"x 3"s and a 4" maple split. The softwood was dry. The maple was in front of my dehumidifier for five days. The draft was wide open. There was smoke coming out of the chimney. The door could be cracked with no smoke spillage. But even opening very slowly from there would allow a lot of smoke to escape. Out of curiosity could it be the cap?
Bingo! in this case the stove was not installed correctly. If your chimney does not draft with no appliance then you are hooking the appliance to a bugsbunny painted thimble on the wall. disconnect the appliance and fix the draft. no big deal. The draft reading will be an eye opener for the installer.Draft is almost never checked for a wood stove testing draft for a wood stove is difficult because it requires a full temp fire so it takes quite a while to get a good reading. And honestly that will not necessarily tell you much. We know there is not enough draft the question is why my bet would be negative pressure in the house combined with little temperature differential
The stove is not drawing, because there is no draft! An appliance can not create draft! I think SWitzer has some explanation of this in his material well written.Figuring out why the stove is not drawing is way more important than a constantly changing number that is only going to tell us what we already know that there is inadequate draft. And no testing draft is not hard with a draft gauge but with a wood stove that number is going to change allot through the burn cycle
Hi. I too am new to epa stoves. I am having a similar problem. I narrowed my problem to outside temps being warm, inexperience with epa stoves and being to cautious. Not putting enough wood in at the start and having to open the door to add more. Before it was good and hot. But each burn is getting better. But still too warm outside.Ok... My installer came out and did his thing. Checked the stove, chimney, measured the draft, and checked the moisture content of my wood.
In a nutshell, my wood was too wet, the ambient temperature was too warm, and I am still figuring out the stove.
I've now got some dry wood inside, the temperature has dropped, and I've been having some success! With this stove in my situation, the fire needs to be started with enough wood for a good burn. To eliminate smoke spillage the door cannot be opened unless the woodstove is hot. When loading wood I just need to think about it! I have had several overnight burns and have been able to restart in the morning off the coals. Morning restarts are dicey if I'm indecisive and open the door twice - smoke spillage draws the attention of my wife!
Cape Breton Island
I'm keeping the draft open for about fifteen minutes...
Now, about load size... When I fill it up at night, I'm keeping the draft open for about fifteen minutes and then closing it for the night. Will there be any secondary burn? Or is it just a slow burn?
