Squisher
I see you're in Canada and the direct vent option you showed a manual picture of is not approved up here.
Thank you, that's what I was looking for.I see you're in Canada and the direct vent option you showed a manual picture of is not approved up here.
I have inspected everything I can see and I see no signs of corrosion or deterioration. No leaks around the chimney pipe that I can see.Just because it was not used does not mean the weather has not gotten to it or that it was installed properly to begin with. We see way to many that were not installed with proper clearances to begin with. How did you inspect it? Did you pull the chase cover and look down the chase to look for proper clearances did you pull the top and bottom vent covers and check for deterioration?
ok that is good how about proper installation? Did you check for that? I am not pushing this issue to be a pita. I have just seen way to many that did not meet the installation requirements and if you will now be running a stove through it which will burn at higher temps for much longer periods of time it can be a real serious safety issue.I have inspected everything I can see and I see no signs of corrosion or deterioration. No leaks around the chimney pipe that I can see.
Not being a pita at all . I appreciate the concern. Safety is #1 I will check dimensions shortly.ok that is good how about proper installation? Did you check for that? I am not pushing this issue to be a pita. I have just seen way to many that did not meet the installation requirements and if you will now be running a stove through it which will burn at higher temps for much longer periods of time it can be a real serious safety issue.
Thank you! This is all info I don't have you guys are awsome!!The reason you will need a full liner if you go through the existing fireplace is because direct connect installs aren't allowed and if venting through a existing ZC fireplace you are not allowed to modify it except for exterior trim pieces and removing the damper to accept a liner.
Thx. The label says it right up front - install in masonry fireplace only
That was for a different stove.Looking back, it looks like your last question has already been covered early on.
So an install through the ZC is probably not an option.
So if I remove it completely, what must be done to the opening to have it suitable for a free standing or is that even an option?
Sent from my SM-G870W using Tapatalk
It's very possible that an insert will not be allowed in the ZC fireplace. Look in the manual to see. If that is the case then another option would be to put a rear vent stove in front, extend the hearth and hook it up to a full liner up the ZC chimney.
It looks like the chimney pipe may be 7" class A HT. Unfortunately the 24" high opening is the controlling factor for a rear-vent wood stove there.If you run through the ZC fireplace to that existing chimney you will need a full flue liner top to bottom as per ULC S635.
If you're ripping the existing factory built fireplace(ZC fireplace)out. Then you are I believe somewhat starting from scratch. And you may be able to re-use the class a chimney pipe you have if it's in good shape and appropriately sized, proper clearances, etc etc.
