Hardly a point worth making, I don't see how a $150 valve could sway the argument one way or another.The advantage that Garn has over a normal gasifier in an application using temps <140* is that condensation and/or cold shocking the boiler is not an issue. A person can start a fire in a Garn at 110-120* and just let it run with no tempering valve or other protection. This is definitely not the case with other wood boilers.
, always start fires with a "cold" boiler and my loading unit works exactly as it is supposed to. I can verify this with a quick glance at the temp gauges on the unit. I just don't see how this lowers efficiency in any way. Sure the Garn and Jetsream don't require RWP and that is nice and all but really its just another trade off when it comes to choosing a system.
![[Hearth.com] Newbie Needs Help with OWB selection! [Hearth.com] Newbie Needs Help with OWB selection!](https://www.hearth.com/talk/data/attachments/115/115727-2fa2f9a02e7eadd637bfa217b1727c32.jpg?hash=y0jdfnhZic)
From the first pieces of sawdust from the powersaw cut into the log ,I definitely do not want to miss out on that last fume leaving the chimney .
SO beware !
![[Hearth.com] Newbie Needs Help with OWB selection! [Hearth.com] Newbie Needs Help with OWB selection!](https://www.hearth.com/talk/data/attachments/115/115881-24a6b4807d6d0250a3441e6821b0def1.jpg?hash=-9A6kb1P4x)
![[Hearth.com] Newbie Needs Help with OWB selection! [Hearth.com] Newbie Needs Help with OWB selection!](https://www.hearth.com/talk/data/attachments/115/115882-4db3230ebdba4287d8e2870115badfa4.jpg?hash=G2QxZAh2_2)
supports my addiction , with exception to the Fume Thing !
