Newbie here with Vermont Castings Reliance 2220
Ok got you just one more question i put everything back togather and started up the stove. Correct me if i am wrong. I lit the pelletts shut door hit start and auger came on. I thought auger only came on when temp was reached???????
It runs all the time untill i hit the stop. I was thinking to unplug the thermocoupler to see if the auger stops running when start up cold and it does. Plug it back in auger runs. Somewere along the line something wrong i feel. Back to the dwraling board. Such a nice clean stove and omg beatulful stove.
Mike, doublecheck the polarity of the thermocouple, that it matches red to the pin that is in the picture that I sent.
Check that there is continuity between the red and white TC wires and also make sure that the TC sheath isn't connected to either red or white wires. An open TC will result in what you are describing.
Reactions: Ssyko
Reactions: Ssyko and Don2222
Bill, I ordered that same combustion fan ... (https://www.ebay.com/itm/PELLET-STOVE-COMBUSTION-EXHAUST-XP7610-BLOWER-MOTOR-4-3-4-Fan-FITS-MANY/173635949081?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649) ... that you steered me to. Was wondering ... how has it been working for you?
I still have the type J thermocouple in my save for / following list ... but curious how you used it keeping it isolated? Below is a picture of my original, but I was told it was "bad", but it's never been tested yet. It looks OK, I plan to test it today. If bad, thinking I might can make a same like mount with big hole, and secure the new TC via J B Weld (rated 600 deg when cured) and or ultra high temp RTV "insulated" from contact?
We have it going, it's purring now, but the blower did squeak at start up. I have that new auger motor / reduction gear box still, thinking of replacing all 3 soon as one operation.
Later ........... Les
[Hearth.com] Newbie here with Vermont Castings Reliance 2220
Reactions: Ssyko
I spent over an hour digging through boxes ... marking them ... looking for the new in box auger motor, no luck (but I did find 4 brass synchro rings for a Muncie 4 speed in my '67 Chevelle that I sold in 1984)... was gonna give up, turned to flip a light switch, there "plain as day" were two boxes marked "Pellet Stove Auger" with a date on each box ... on that shelf with spray paints and glues, wax, etc ... one was the OEM one which developed a noise in the gear box ...which I replaced in 1996 ... and the other was the NIB still, never used one that I bought in 2013 when I thought I was gonna need one.
I went to my files, pulled out my pellet stove file where the OEM thermocouple was stored too, it's end looks black from soot, but no breaks so I checked it for continuity, looks good as the meter set on resistance went to 0.00 (closed circuit, is good) from 1.00 (open circuit, is not so good) immediately. I was trying to remember why they sent me one ... stove was acting weird then, not burning good and the technician thought a new thermocouple would fix it. It did start running right soon enough, but I also was in a phase of trying different brands of pellets (which is why I kept it since 1994).
Reactions: Ssyko
This was the TC that I bought https://www.ebay.com/itm/Thermocoup...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
But the part # that you posted should work as well and it's cheaper.
What is important is that it is type J and the element is insulated from the outer metal sheath..
I know this was a few years ago, but I am hoping you are still here after a recent reply. That link was for a 12" type J TC, I was wondering if it's too late to ask you how you went about mounting it. The link I am looking at is about the same, but only 6" long and it's still longer than the depth under the stove's mounting place. I figure if you got a 12" in there, I could get a 6" in there. https://www.ebay.com/itm/355729246552
I recently put my OEM one back in the VC sent me a replacement for 30 years ago, and the OEM tested OK a couple years ago, and the stove is doing great, but it doesn't hurt to be prepared.
Thanks ..... Les
Reactions: Ssyko
Hi Les, I think that I just reused the existing compression fitting. The ferrule was still loose, not compressed, so the new TC was able to slide in and be snugged down. It mounts in a small plate so you could always make something. A 1/8” NPT would probably work, not sure of the OD of the TC probe, but probably 1/8” also.
Bill
Reactions: johneh and Ssyko
Bill
Thank You ...... So not the whole 6 or 12 inches need be inserted into the 3 or so inches space? Sounds like just get a couple in and is OK.
Les
Reactions: Ssyko
I thought must be , but wanted to confirm my thought. :cool:
Reactions: Ssyko
