Have you checked to make sure the area where the crock passes through the wall is done correctly? Do you have 36" to the wood trim on the sides of the brick and what is behind that brick?Can I buy a new set of door pins at Ace Hardware?
Had to remove doors to get into house and this bottom pin broke and it will not move. Must be drilled out. Starting to come together. Also having my old house I bought a few years ago remodeled. I will be putting a Timberline insert into my kitchen fireplace this winter. House and main structure was built in 1890 but has had the necessary upgrades since.
Do you have the liner to install the insert?
Either from the top or through the stove. It is way faster and easier than pulling out the insert every year. And way safer as well as much better performanceHow do you clean a chimney liner when it's hooked up to an insert?
Timberlines are every bit as good as fishersNot sure where you can buy those new door hinge pins. They are 3/8" rivets if I remember correctly. @coaly might know of a source for those pins. I think I've seen them come up on eBay in the past.
Looks like you've been busy, and making progress. Just curious, why did you decide on a Timberline insert for the kitchen fireplace? Bob Fisher actually built his first wood stove, and set it on his fireplace hearth because he didn't get enough heat from his fireplace.
I bought my Grandpa Bear from a couple who hooked it up on their fireplace hearth. They loved their Fisher stove. They owned it for 25 years but they had to buy firewood and it was getting expensive. Just an FYI, Fisher inserts are usually for sale on Craigslist![]()
So there is no combustible material on the back side of that brick wall? It's all masonry?Its chimney behind the brick. And yes, I made sure it got place at least 36 from the brick wall. My Shenandoah was quite taller and never any issues. There is an aluminum heat shield hanging from mantle where the stove pipe connects to chimney.
I think Todd knows I'm doing it right
Ok so just to be sure if you look on the other side of the wall that that brick is covering it is brick the same as what we see there?Nothing combustible. I'm even going to run brick on the wall each side of the 4×4 vericle mantle. You should be able to see where the old wall paper was ripped off
Having it put in with a full stainless liner right?But I think you were talking about my kitchen fireplace where I'm havinh a timberline insert put in this december
Because I do this for a living every day and see the really stupid dangerous stuff people do all the time.Yes, there will be a liner, it comes with it. And of course a bundle of fire retardant high heat special insulation will be behind it. I forgot what the stuff is called
I will even get a nice new heat shield and flexible flu.
Why do you sound worried?
