I'm a bit slow on the uptake..where is the pic?it really doesn’t look that bad in the photo.
Yeah, I meant pneumatic impact. The only electric o e I’ve ever used is my 18V Bosch, and it doesn’t gmhave enough torque for a bolt like this. Also, I think those extractors you posted are only for hex bits and hex head bolts and screws, not socket head.
I’m really surprised you can’t get a hex key into your bolt, it really doesn’t look that bad in the photo. What’s the issue, there? You know it’s metric, right?
![[Hearth.com] New-to-me Firelight issues [Hearth.com] New-to-me Firelight issues](https://www.hearth.com/talk/data/attachments/259/259333-1a5a450e90fdae55bc362f54e3988223.jpg?hash=rSHSBjOCGA)
![[Hearth.com] New-to-me Firelight issues [Hearth.com] New-to-me Firelight issues](https://www.hearth.com/talk/data/attachments/259/259335-a3f102a91f8f4bff355972ce509e03d3.jpg?hash=_8D7aZ3utV)
Woodmans says the screw uses a 5/16" Allen wrench.
Replacement stove parts | Woodman's Parts Plus | Stove Gas Wood Stove Parts
Woodman's Parts Plus offers over 20,000 in stock parts for your wood, coal, gas, oil or pellet unit, as well as barbecues and outdoor power equipment. Over 400 old and current manufacturers, with unique parts and patterns.www.woodmanspartsplus.com
post #28 in Ray’s other thread.I'm a bit slow on the uptake..where is the pic?
5/16” would be 7.9mm, although being made in Norway, I'm surprised they're using SAE.In fact in hex keys and bits, metric is all I own -- or can find at the moment at any rate; 8mm (size of the Jotul key, correct?) doesn't seat, 7mm rattles around. Hardly seems possible someone replaced the original bolt with a SAE bolt, does it? But if there's an English equivalent to say, 7.8mm I'll head to Auto Zone and buy one, since I borrowed my buddy's impact wrench (meant to say pneumatic) (considering I'm a technical writer you think I'd express myself more articulately).
I was under the impression those extractors were for round head bolts/screws -- granted not this application. At any rate I'm not there yet, and none of the set I got at the bigbox yesterday are large enough anyway.
Might be faster to drill it out and retap it.
Hah... I typed this early this morning, but never hit "post". Here it is, too late, anyway.
I see begreen posted Jotul states 5/16" wrench, but I suspect that's just someone's attempt at a metric conversion for us inch-folk. Perhaps that's why it's jammed and stripped, someone put a 3/8-16 SHCS (takes 5/16" wrench) in the hole tapped for a M10x1.5 (takes 8mm wrench).
Now that it's stripped, it might be time to grab a left-hand drill bit and go at it. The OEM bolt is black oxide, which is going to be hard, so a coated bit is your friend. If the bolt is just frozen with rust and not truly buggered and stripped, the left-hand drilling will often spin the bolt out before you even get thru it. If not, now you have a new hole to drill to tapping diameter.
A 3/8-16" takes a 5/16" drill for tapping, and the M10 takes an 8.7mm drill (or bit "R"), which is just slightly larger than 5/16". Since left-hand bits are usually sold in sets of fractional size, I'd be using a 5/16" left-hand bit either way. Then you can just tap 3/8"-16 if you don't mind bastardizing the stove with an English thread, or re-drill for a proper M10x1.25 tap.
Welcome to the Firelight 12. I hope you like working on stoves!![]()
Instead of a left hand bit, you could also try an easy out.
So, I was just thinking thru this problem, and realized there's a complicating factor, here. I believe that delicate and insanely expensive refractory chamber has no corresponding hole behind that fastener. I'm wondering if someone else can confirm. If that's the case, the bolt likely pushes into it a bit, but does not penetrate. This creates two potential issues:
1. Drilling and tapping might result in accidentally punching thru the refractory during either operation, although this could be mitigated with a few simple techniques.
2. Drilling the fastener out will result in any part of the fastener currently penetrating the plate to remain trapped back there, no way to remove it, although you could probably just slide it down out of the way of the new fastener.
In this case, as much as I hate the things, Mech-e's suggestion of an easy-out is probably the best next step. These things more often break than work, in fact I just broke one this past weekend, but sometimes they're the least destructive thing to try.
The OEM bolt is a hardened black-oxide socket-head cap screw, and assuming that's what's still here, you're going to want a cobalt bit. So, you're likely buying a bit anyway (unless you happen to already have a full set of coated bits), and so you might as well go lefty. With any luck, you may spin the fastener loose before even reaching for the easy out.
I would go with McMaster-Carr extractor item 2566A15, and use McMaster-Carr drill 3474A16. I've never tried this type of extractor, but it has to be better than the standard easy-outs I normally use. Also, note the left-hand bit I'm calling out is 1/64" larger than the recommended pilot hole for this extractor, since lefty drills don't generally come in the spec'd 13/64" pilot size for this extractor. I expect this is fine, as this extractor is spec'd for use with 1/8" pipe (.269" to .312" ID). You may want to check that with McMaster, you could always left-drill it to 3/16" and then right-chase it with the spec'd 13/64", but I wouldn't think that should be necessary.
If all that fails, there are two ways to go at it from there:
1. Drill and tap very cautiously in-place. This might mean installing a stop collar on the bit, so you can work 1/8" at a time, and not worry about punching completely thru the refractory when you do your tap drill. Then slide the remaining tip of the old bolt aside (it would be trapped between back plate and refractory), and start tapping. Start the job with a plug tap, and finishing it with a bottom tap (or hand-grind your plug tap to make a poor-man's bottom tap).
2. Remove the entire fireback, so you can drill that bolt without concern. This means you'll be doing a lot of gasket work for the re-install, but you'll know you have a good stove when you're all done.
Again, that OEM bolt is black oxide, so you're going to want a coated bit for the drilling. I'd use a 5/16” cobalt steel lefty bit (McMaster-Carr 3474A21), and then chase that with a letter "R" bit (or 8.5mm), and tap it M10x1.5mm. If you want to save some cost and effort, you could simply tap 3/8-16 right after the initial 5/16" drill. I can provide those part numbers, if you end up going that route, but I'd be apt to try the screw extractor mentioned above, first.
![[Hearth.com] New-to-me Firelight issues [Hearth.com] New-to-me Firelight issues](https://www.hearth.com/talk/data/attachments/259/259512-785681c926dbae2027aa13fbafa821e0.jpg?hash=XE_QR4MSQj)
![[Hearth.com] New-to-me Firelight issues [Hearth.com] New-to-me Firelight issues](https://www.hearth.com/talk/data/attachments/259/259513-a4a1755ac2aba6defe7228584929e73d.jpg?hash=fnRnZJB92o)
That could work, if it’s the right size. The extractor is actually meant to be held in a tap handle:
Micro Trader M3-M12 Capacity Handle Adjustable Tap Reamer Tapping Wrench Tool Amazon product ASIN B077M6XPVL
Note this style is less common than t-handle style, but offers more torque. Just check the size, each handle only fits a range of taps or extractors.
I would try heating the surrounding area with a mapp gas torch, to try to get the hole to expand away from the bolt threads. Might be a danger of overheating the cast iron..I doubt it but I don't know.
Then soak the heck out of it with Permatex Fast Break or other penetrant, for a few days, re-moistening it often.
While you soak it, and before you try to remove it, tap the bolt with a punch and hammer to try to break the threads loose. Again, be careful..you could crack the cast iron if you pound too hard..
With the bypass open it won’t hurt that cat. Even if it’s intact, I doubt it’s still alive. I’ve had to use a torch anytime I remove a fireback in a 12.
