F4jock
Lower the score and open the draft on low fire. OAK still a good idea.OAK- this isn't exactly easy for us to install. We would have to cut another hole in our building. its possible and an option if need be, but I would like to put this off for now.
in regards to the sooty flame, should we try opening the draft more on low? the stove is in my dads garage so he is the one playing with it most times. he said he found the stove seems to like the draft right around halfway open, maybe open or closed slightly more/less but generally in the 50% area. just wondering if maybe we need to maybe close it way down to like 25% on low?
as for our current exhaust setup- I found what I was talking about before, the Equal Vertical Length calculation. it would be easy for us to try lowering our score if you guys think that might help. sorry I had the score wrong its .5 for vertical not 1.
Current setup:
45 elbow- 3
2' straight horizontal pipe- 2
cleanout tee- 5
5' straight vertical pipe- 2.5
that gives us 12.5. we could pretty easily remove the clean out tee and vertical stack. that would give us a score of 5 rather than 12.5. our only reason for not originally going with that route was I believe our directions mentioned having some section of vertical pipe for good venting. however is searching around it seems straight out the back with a cap would be acceptable.
last night I was in the garage, actually dropping off a 2nd pallet of pellets, and was looking at the stove. burning on 5- high, we have a nice bright flame and everything appeared to be working correctly. the temp on the side of the stove said 32 and it was single digits outside, probably around 5. So I assume our stove is working as it should.
the bad part for us, which is unrelated, is that our torpedo heater decided to quit yesterday. So today my dads first priority is to try to get that looked at. We are also hoping to get some insulation picked up within the next few days.
