huauqui
Burning Hunk
Looks like a gorgeous install. Can't wait to see it all finished and burning. Great detailed pics to thanks for sharing.
From a circulation design stand point, there may be merit to introducing another room's air space into the system. It seems very difficult for the average home owner to model this type of air movement to gauge benefits before implementing a design. Then there are the issues of fire and sound containment with the addition of a pathway to another room. I'm life experienced enough to know neither of these issues should be handled with a "shoot from the hip" type of approach. Time to do a lot of research or pay some licensed pros for their time.Let's hear some of your thoughts....im interested. Do you think there is merit in drawing the air from another room vs from the stove room? I would like to get as much air circulating as possible. My new home build will be very tight with little air infiltration. What sort of things would you try to incorporate?
Have you posted what you are using for stone? Curious how you will be covering your hearth top.
It will be awesome!!We're using quarried stone from a company called Masonal Natural Stone . We went with a line they call Niagara Valley (http://www.masonalstone.com/mobile/index.php?page=Valley_Estate_Cut_Heights&&gid=32#PhotoGallery).
It's stone that's blasted from various quarries in Canada and then it is cut into Veneer in 2 and half , 5, 7 and and half and 10" heights and of various lengths. All prices are hand stoned as well.
The hearth top stone is going to be 3 pieces of sandstone that has a textured top to match the rest of the stone.
Here's some pics of the stone I brought in to the house ready to go for tomorrow.
The last pic is the hearth top pieces.
DUDE!
That is the mantle I wanted, but was voted down by the Mrs.
Can you share anything about how it was fabricated and finished?
perfect, couldn't have asked for more. I may use your pictures to make one final presentation. We aren't completely locked into anything yet, and I can see a way to reverse engineer this to fit my application.
That's going to be one very sharp looking fireplace. The stone looks great.
Just looking back at your installation and had a couple of questions.
Did you insulate your B-vent with roxul in the basement wall? I'm thinking about doing this to get the air a bit warmer at the other end. I haven't closed it off in my basement ceiling yet so I still have the option.
Did you apply cement board or metal flashing to either side of the fireplace pad between the pad and inside walls?
BTW nice job adding a bit of B-vent between the fireplace and OAK duct. My installer foil taped the duct directly to the intake on the bottom of the unit. The FP30 manual and my dealer both recommend this, but the opening for the duct connection gets way too hot for that. The sleeve on my duct actually starts to melt on long burns. PE should really revise this detail and provide 2 feet of 4" B-vent with the unit. I'll be making this change.
What caused you to replace the A-body stove with the new b-body? How long did you have the original?Great, thanks! I'm not sure if it's worth the cost, but I am considering it.
If anyone else can think of a good reason why I shouldn't apply roxul to the power B-vent please chime in. I believe the clearance is 1" from combustibles, but roxul doesn't burn (I've tried) and obviously a very poor thermal bridge.
Regarding the floor protection; my setup is similar to yours with the raised hearth. Only difference is the non-arch design. The intake grill under the ash lip seems to be in the perfect location to allow the passage of embers that may roll out and land on the hearth. With the b-body design, the lower sides of the secondary fire box walls are now open, potentially exposing adjacent combustibles at either side of the stove base. In fact over the time that I've had the b-body I've noticed ash collecting under the fireplace on the metal base under the stove in the area of the grill opening. I think some of this ash may also be coming from the 6 air intake holes at the front of the unit as well. The FP30 lower air chamber is not very well sealed up from the under carriage of the stove. The design of the raised hearth was based on my original a-body which had secondary walls completely enclosing the stove. Now with the b-body in place I'm wondering if I should think about how stop ember penetration through the bottom grill. Maybe I'm paranoid but I think it's a legitimate concern judging by the ash that can be seen collecting on the base.
