Ha....i know what your saying......with a lot less slot/grill on the 30 does that affect performance? I'm going to be pushing this stove non stop and need all the help i/it can getThere are slots on the straight FP30, but hard to see due to the shadow line created by the top "hood". The manual illustration shows them better. There is a distinct benefit if you go with the look your wife likes the best.
It's going in a new house build. Insulation and air sealing will be excellent. It's the 3100 main floor SqFt is the challenge. It will be supplemental behind a f.a.f, but wanting it to do a good chunk of the work. I am considering how to duct, but with the unit on an outside wall, it limits a lot of options, besides basement drops.I would expect that PE designed both to work well. If the house is challenging to heat then it may need more solutions like ducting the heat out or improved sealing and insulation?
Ha....prolly shouldn't put windows in either.......well maybe we should just live underground. But seriously, part of this dream home dream includes looking at the fire and out the windows in the same view. But thanks for the design tips.If designing new I strongly suggest putting the fireplace in the interior and not tacked on an outside wall. There are many advantages including better heating. The other suggestion would be to avoid cathedral ceilings.
Ok thanks, with the summit I would require a masonry "box" to allow for the insert? That would create a significant cost I'm assured. When looking at the specs....there appears to be no difference in the heat output? Possibly someone could explain if there is a difference. Also there is no second floor, just the 3100sq ft basement that will prolly have around 1600sq ft finished. The cathedral ceilings are not going to be monsterous I'm hoping to take them from the 9' walls to a 11-6' scissor.If you have an open floor plan, and have the steps to second floor(if there is one) on the other end of the house from the stove room, and possibly a ceiling fan in the stove room, you may get a nice convection loop going on. I have very high cathedral ceiling, then entire house, with some rooms upstairs and a large loft, and have no issue due to the cathedral ceiling. I am not even using the ceiling fan this year, and the convection loop is doing great. I am either lucky, or there is some myth the the cathedral ceiling theory.
With that large of a space, you may want to reconsider and get the Summit insert, as it protrudes out more than those face mounts you're looking at, and will get more heated air out into the room & house easier.
Hi folks,
Been lurking here for a few months now and finally pulled the trigger on a Pacific Energy FP30 Arch with a remote vent/blower kit to heat the rec room in the basement below.
It is being installed today and I'll update this thread as the work progresses. The fireplace is being installed now and the stone work will follow in Dec. My stone guy is going to be beefing up the floor joists in the basement by installing a 3 ply 2 x8 beam on posts (cradle), across the span, about 24" out from the back wall, to support the huge weight of stone going up the 18ft wall.
Here is the first photo of the platform it is resting on.
Here's the second with the first section of pipe installed;
Here's the 3rd with another section of pipe:
I had the PE Summit insert installed 2 months ago. It came with a broken crown molding. It has been over 2 months and dealer can't get an answer. PE hides behind an email. They won't respond. Does anyone have a phone number for this company? There is no number listed on their site. I am embarrassed for not doing more research on this company.
PE stands behind their product, it's the dealer that is slacking.
Even though I haven't had to deal with PE on an issue, everything I've heard and read about PE and their dealer/customer support has been really positive. That's one of he reasons I went with the FP30.
I just wish they would have a customer support dept that's easy to contact by phone to deal with customers that are getting screwed by poor dealer service. Just having an email address on the website that may or may not get a response doesn't cut it in my book. Being able to talk to an actual person is the proper way to support your customers. We shouldn't have to go searching for ways to contact them.
