"1.8 lbs/hr. this is a 40 lb. bag in 24 hours. this is what is usually consumed by an average pellet stove running at its lowest or nearly its lowest setting."
I'm going through this exercise yet again, trying to figure out how much of our situation is house-related vs. how much of it is stove related.
We are at the very end of a 55 lbs. hopper full of pellets that's been running since about 10:50pm last night. We've been running at feed setting 4 as recommended in the owners manual. The owner's manual specifically says not to run the stove on high or low on a regular basis, but to run the stove on a feed setting of 4. We probably have another hour's worth of pellets in the hopper, maybe two hours worth.
EDITED: Full hopper of 55 lbs. pellets took almost exactly 27 hours to burn at feed setting 4, which corresponds to almost exactly 2 lbs./hr.
I'm estimating that gives us a feed of about 2 lbs. per hour. Mike, I believe that's what we calculated when we did this last year about this time. That gives us a BTU production of 17k/hour, or 40,800 BTUs in a 24 hour period. This BTU production agrees with the stated specs for the stove:
8500 to 42,500 BTUs. Napoleon states that this stove is rated to heat 800 to 2000 sq ft. Our house is 1410 sq ft.
I read on a Dept. of Energy web site that a stove rated at 60,000 BTUs can heat a 2000 sq ft house, while a stove rated at 42,000 BTUs can heat a 1300 sq ft home. So, yes, our stove is slightly undersized for our space.
http://energy.gov/energysaver/articles/wood-and-pellet-heating
Rather than lose money on swapping out stoves, we've been trying to insulate and seal this house, and that has helped.
I am considering selling this Napoleon and buying a bigger Englander off of AM FM Energy's web site, but for the moment I am fighting that off. After all, a bigger stove burns more pellets, so a bigger stove will cost us more money to run, in addition to the money we'd lose on swapping out stoves. So if we can get away with hanging on to the BTUs we already make we'll come out money ahead, no matter how much of what fuel we burn.
It is frustrating to deal with the inconsistencies in stove ratings vs. area heated.
Mike, if we were to swap out for a larger Englander, what stove and what size would you recommend?
