Good to hear there is progress. Yes, modern stoves run quite differently than the old preEPA variety. This takes a bit getting used to and then it is quite nice. Any leakage around the stove door gasket is unacceptable. Just a small amount of leakage can make a large difference in how the stove burns. For example, I just put a new gasket on our PE T6 stove 2 days ago. It is not the OEM gasket, I had to use what I could find until an OEM gasket can be sent to me. The gasket is leaking ever so slightly in spite of being in new condition. I notice this in the flue temps which are too high and in the position of the air control which has to be closed further and there is less secondary activity than there should be. It's still there, but not as much. The new gasket is too stiff and is not making as tight a seal as it needs to. This can't be measured with a dollar bill. That is being clamped tight. But the fire and flue temps say it all. Hopefully I will have a new gasket by tomorrow or Monday and the stove can return to normal operation.
You can not get reliable reading of flue temps from the surface of a double-wall pipe. It takes a probe thermometer. Normally our probe temps are about 100F less than the stove top temp, but with this new stiff gasket they have been the opposite, reading about 100-200F higher. Normally at peak burn the stove top is about 600-650F and the flue about 500-550F.
