Wow, that's a big leap in output. Was the Castine way undersized or will the 600 be an elephant gun?Well, we did it. My wife and I just bought a new Jotul F600. We are going from the Castine up to the big boy.
It was way undersized.Wow, that's a big leap in output. Was the Castine way undersized or will the 600 be an elephant gun?![]()
Somewhat comparable climates as well..We made the same size leap from the Castine in same sized house. No regrets.
Good to hear. I'm really looking forward to the bigger stove.We made the same size leap from the Castine in same sized house. No regrets.
We got the matte black so I'm assuming this will be less smell than breaking in an enamel stove. I will just open the windows a bit during the break in fires. That worked fine with my Castine.Any chance you can fire it up in the driveway to burn off the paint smell before bringing it into the house? I wish I did that with mine in hindsight.
Just the opposite. The enameled stoves emit much less breakin smell. We hardly had any at all with our blue-black Castine. The matte black is a painted stove. It will definitely have a smokey start. The first break in fire won't be bad because the stove temp will be low. But once the stove gets over 400F it will stink. Take it up to 600F right after the breakin fires in order to fully bake the paint finish. Open windows and put a fan exhausting in one to keep the smell from being overwhelming.We got the matte black so I'm assuming this will be less smell than breaking in an enamel stove. I will just open the windows a bit during the break in fires. That worked fine with my Castine.
Thanks for the advice, begreen.Just the opposite. The enameled stoves emit much less breakin smell. We hardly had any at all with our blue-black Castine. The matte black is a painted stove. It will definitely have a smokey start. The first break in fire won't be bad because the stove temp will be low. But once the stove gets over 400F it will stink. Take it up to 600F right after the breakin fires in order to fully bake the paint finish. Open windows and put a fan exhausting in one to keep the smell from being overwhelming.
That’s a hell of a nice Christmas.Well, we did it. My wife and I just bought a new Jotul F600. We are going from the Castine up to the big boy.
It gets installed the day after Christmas, first thing in the morning. I can't wait! Merry Christmas to us!
Pictures of the stove will follow.
Be sure to read the manual carefully regarding where to place your stove top thermometer before you start running the stove up to 600 F. You will see that the thermometer is placed on one of the corners of the top. I have an F 600 and have my thermometer on the back left corner. There is a big difference in temperature readings between that location and the center of the top. For example, when my stove is running 400 F on one of the corners it is well over 600 F in the top center when I hit it with my IR thermometer. So, if that ration holds (my IR thermometer tops out just above 600 F) and you heat your new stove up to 600 F on a corner you may well be running in the 900 F range at the top center. That's hotter than I would be willing to run my stove. I've had my Jotul F600 for about four years now and usually run it around 350 F - 450 F (on a corner reading) and it heats my 2200 sq. ft. upstairs area fine.
I will let you know. Our Castine ran well too but, similar to your situation, it just wasn't big enough.Congratulations on the F600. That will be my next stove although my f400 is a tank runs great from day 1 , (12 years now.) My bi-level house approximately 2300sf needs more then Castine can carry.Oh well, would like to hear from you how this changes things at your house.
I am really looking forward to having the firebox room to choose my fire size. Like you said, I can opt for smaller fires in shoulder season, but also have room to build a big fire on really cold nights.You're gonna love it. We're just under 2200 sqft and probably under insulated and it's toasty throughout the house. The trick for us was building the right sized fire in the shoulder season, but it is handy to be able to build smaller fires when necessary.
I have done this in the past but want the stove company to do the full install for me at this point. I'm not keen on moving almost 500 pounds of cast iron myself. Also, for liability reasons, I want the total install done professionally from start to finish. It's gonna be a smoky few nightsIf you can get them to deliver it early, you can do the break-in fires outside.
