Also how of seasoned firewood do you have? I only have 1 year this season. It's all I had transitioning from the old clunker to this top shelf model.
BUT...I Have not had stove top over 600 yet, haven't really needed to spur it. Heat pump set at 68 doesn't kick on at 5:00 AM like last year. Wife enjoys running it, also. Last stove worked well but was more work and I had to run it harder, 4-5 trips to the basement instead of 2.
I am a bit leery of engaging the cat at 300, trying to wait untill stove top is pushing 350. What say y'all? Would a 300 degree stovetop equal a 500 degree cat? Thermostat says so but...
Now that's a good question. I know when left cat - open, it seems to continue to heat up. I don't know if it can damage the cat while disengaged. Whenever the air is opened up there is a light show for awhile too.This thread has piqued my interest in a hybrid. I really like the looks of the stove! I am current running a quad 3100 (tube stove). Can the Ideal Steels be run the same if we wanted to have a fire in the window or must the cat be engaged all the time? I like the idea of a longer controlled burn when leaving the house or overnights but if we have company over or simply want the flame view will leaving the cat disengaged hurt anything?
Oh yes, that helps lots. I have checked mine once (about 6 weeks in) and it had a light accumulation of very fine fly ash. Only noticed it once I vacuumed one pass, then compared to the uncleaned part.Maybe the wood, being slab- wood helps drying time?
That look is what let me talk the wife into a new stove, so don't knock itI like that solid black look, I think it helps tone down all the odd angles on that stove. Glad to see you didn't get all that crazy fru fru stuff for it, its a box for fire for crying out loud.
You don't ever HAVE to engage the cat, but you will be hurting your efficiency. I don't see any reason not to engage it though. The manual says you can run the stove at 1/3 air with the cat engaged. With a full load of wood at a good temp (500 - 550) before you engage the cat, you will get A LOT of heat at 1/3 air. Why not let it clean up the stuff you are missing and get that extra heat.This thread has piqued my interest in a hybrid. I really like the looks of the stove! I am current running a quad 3100 (tube stove). Can the Ideal Steels be run the same if we wanted to have a fire in the window or must the cat be engaged all the time? I like the idea of a longer controlled burn when leaving the house or overnights but if we have company over or simply want the flame view will leaving the cat disengaged hurt anything?
Question for you smokedragon, and any other IS owners that haven't mentioned it, but do you have the soapstone liner, and do you believe there is any benefit to this ?
I'm getting an IS (have it on order), and have opted to not have the liner or ashpan (although i do want the soapstone side panels), but curious if this would have any performance affect ?
The ash pan is worth its weight in gold.................I think there may be some tiny tiny advantage over firebrick because it is denser (so it should hold more heat). But we are talking maybe a few hundred Btu per hour. I would have to run the stove both ways to know for sure, this is just my best guess.
But I agree with cableman, it seems much heartier and more durable than firebrick. That alone makes it worth it to me.
I opted for the ashpan on mine and I wasn't sure I would like it or not. I am glad I did.
The ash pan is worth its weight in gold.................[/quoteYep, I think it could be awkward removing ash over the andirons. I use a 8",or so wide flat shovel for 90% of my stove fiddling.Glad I got the pan.
Energy storage is a product of mass and specific heat, and that is the magic in the soapstone construction. A 500 lb soapstone stove really does store more energy than a 500 lb iron stove. You have to consider the mass and SH on both the soapstone and firebrick, to settle this one.I think there may be some tiny tiny advantage over firebrick because it is denser (so it should hold more heat). But we are talking maybe a few hundred Btu per hour. I would have to run the stove both ways to know for sure, this is just my best guess.
I made my own ash rake (flat 2" by 5" steel welded to a 28" piece of 3/8" conduit). Rake the ash over the center, and done.The ash pan is worth its weight in gold.................
I don't disagree with you, but the lining is a small amount of soapstone compared to an entire stove made of it (and I think it is thinner than what they use for the outer walls of their soapstone stoves). I don't know that that amount will make a noticeable difference.Energy storage is a product of mass and specific heat, and that is the magic in the soapstone construction. A 500 lb soapstone stove really does store more energy than a 500 lb iron stove. You have to consider the mass and SH on both the soapstone and firebrick, to settle this one.
