I came here to say this. The OEM must also prove that the modification lead to the failure. Ford got into trouble over this claiming that they wouldn't honor transmission warranty problems on Mustangs because the owners changed out mufflers.Search Magnuson - Moss Warranty Act. Folks on car forums state that the burden of proof is on the vehicle manufacturer to demonstrate a modification voids warranty.
Wife's dodge half ton developed a hole in the rad last week.I didn't fix it, the shop did. Wife said the shop said that the fan (must mean the electric one) was contacting the rad?? It was actually reasonable for a rad and water pump (might as well just do that on a high mileage vehicle when it's easy to get to). I feel guilty for not fixing it myself, but oh well...I have enough stuff to do around here...Uh oh lol
What happened?
I don't think his issue was in the snow, but more so icy road surfacesYou could probably find the smaller stock wheels on Pilot forum classifieds
I suspect an all-season will good snow reviews will make a big difference on the Pilot.
No modes. It's a 2014. Honda always lags behind in tech. Instrument menus are confusing, no touch screen, it still uses an actual physical key.Does this Honda Pilot have different traction modes ?
To the point of shocks/struts, this vehicle has 150k miles correct? If you have yet to replace, they are almost guaranteed to be bad.Are the roads smooth or do they jolt your car and make your wheels jump like they do in Michigan?
How are the brakes and suspension? Anything causing it to brake unevenly?
Worn shocks/struts can make it handle crooked, especially if they’re worn unevenly. One of my vehicles would start to go sideways on downhill bumps before I replaced the shocks. Another one would hop when approaching stop signs before I replaced the struts. Even a broken sway bar link can make it handle off kilter. I even had one car where the bar itself snapped inside the bushing, so it wasn’t as obvious so find it.
Brakes/rotors are brand new, I just replaced them.To the point of shocks/struts, this vehicle has 150k miles correct? If you have yet to replace, they are almost guaranteed to be bad.
50-100k miles is the max you can expect life on shocks/struts. They slowly deteriorate. I have seen may people believe theirs are fine until they replace. You can pop the lower rear shock bolt off and compress it to test it. (I'm pretty sure that is not a rear strut but I could be wrong).Brakes/rotors are brand new, I just replaced them.
There a no suspension issues, at best I might want to get an alignment after this winter and the potholes. Although I can't say we've had much of a winter. This week the temps will average out at 50ish with one day potentially getting to 65! What the heck.
I already know what this means. It's going to snow in May again..and feel like the endless pseudo winter we had about 6 years ago.
It was something I had my wife check when she went in for inspection to the dealer and they said no they are fine. Shocking I know. I normally do or did a lot of work on my cars but am too busy aside from brake jobs and rotations.50-100k miles is the max you can expect life on shocks/struts. They slowly deteriorate. I have seen may people believe theirs are fine until they replace. You can pop the lower rear shock bolt off and compress it to test it. (I'm pretty sure that is not a rear strut but I could be wrong).
No issues of caliper pins binding or anything? Just covering all the bases.Brakes/rotors are brand new, I just replaced them.
That I don't know. I usually only pull a wheel and test brakes when I suspect an issue and usually I only suspect an issue when I hear noise or pulling or excessively quick or long braking.No issues of caliper pins binding or anything? Just covering all the bases.
Same here, when the lakes warm up prematurely, it dumps back as lake effect and can snow into May.
yea I heard that too on some of the older american cars. That's not a problem today, at least it isnt for any car I would bother with.it definitely is all about the tires. if you get narrow tires but you need to get the same hight to keep your speedometer the same for looking at and for the computer so it doesn't run rich or lean. if you get a narrow set of tires on a different rim there will be more pounds per square inch on the road and make like a heavier car. wide tires in the snow make for a lighter psi on the road so there will be less traction. if you are on true ice they don't make a tire that can handle true ice snow and slush are different than ice. if you are on ice you would have no control at all. if you don't believe me get in a true ice spot and see if you can move and or brake. if you are coming down a hill and start to slide take it out of gear and you will see that you will have to lighten up on your brakes and you will stop. if you don't take it out of gear you will have to over come the drive forward plus the brakes. for what i'm saying all you have to do is try it. the best in snow that i have seen is the subaru. i have heard about honda's in the snow around here. besides the tires it's all in the center of gravity that someone touched in a above post. also be aware that some vehicles when you run studs on them beat the bearings and transmissions. on some cars... i had two friends in the transmission biz and they would laugh at studs for what they do to these cars.
I cant believe it has been this long but about 18 years ago, I bought a truck because I was sick of sliding around in a car. For 3 years afterwards, it barely snowed at all.Used the snowblower once this winter. And even that time it was just a little above what I would just push to the side of the driveway.
if you keep buying we'll get no snow and for those of us that don't care if it snows again that's greatI cant believe it has been this long but about 18 years ago, I bought a truck because I was sick of sliding around in a car. For 3 years afterwards, it barely snowed at all.
I bought new snowblower last winterNever used this year.
