I would recommend you put it further from the corners for couple reasons. Maybe 9 or 12" instead. 6" is the minimum for the 1100c. You have a big hearth with plenty of wiggle room and bringing it away from the wall will bring the flue centerline deeper in the room which may be a better match for a larger stove if you upgrade.
Ray, tiles should be set in latex modified thinset. If using large stone or brick, I think type S mortar is recommended.
You are on site and have the full view. The first picture posted shows class A in the wall which I was taking for a thimble, not the end of the tee. The outside shot makes me a bit queezy.
Good to see you are correcting this.
