I
ISeeDeadBTUs
Guest
But 350kBtu WITHOUT storage would be really bad for him. Don't forget Kirk seems very new to many of the concepts behind wood-fired hydronics and storage.
I sure agree with adding storage during the installation if you don't go the Garn route. It's better to get this out of the way up front than to say year after year "I'll get to it", RandyFrozen Canuck said:knjne said:OK. I have been reading this forum for quite some time and am ready to buy.
You guys (and girls) are a great wealth of knowledge. But I have some specific questions.
We have to heat about 5000 SQ/FT including upstairs and a basement. I would like the easiest way to do this. I know it will take work, but a $450 propane bill for the last 4 weeks has pushed me to this point.
We live on 10 acres and have a lot of dead trees. The problem is they are mostly Poplar trees and some Elm killed by Dutch Elm.
So here are my questions.
1. I will buy wood if needed. I would like to load as few times as possible per day. I work quite a bit.
2. What is the best (in your opinion) outdoor boiler for this application.
3. In the future I will add a water holding tank. I see from this great forum that this is the way to go.
4. Are there gasification boilers that will take full logs? I do not have a splitter, but will buy one if I have to.
Any other suggestions are needed! I am about to spend a load of money and want to make sure I do the right thing!
Thanks in advance for any help.
Kirk
OK point by point.
5000 sq ft means you need large, think 350k/hr fire rate for the boiler & 1500 gal storage maybe larger. Calculate how many btus you want to store, base this on your schedule/lifestyle, then find a boiler that will get that number of btus into storage in the time frame you are willing to fire it for. That way the system works for you, not the other way around.
1. "I will buy firewood if needed." I agree with others ppl statements that you will need to buy wood, or find from other sources, at least until you have your own supply dried out 15-20% M.C.
1b. "I would like to load as few times as possible per day. I work quite a bit." Me too, bigger means less firing....smaller means more. Makes sense right?
2. "What is the best (in your opinion) outdoor boiler for this application ?" I dont think anyone here would recommend that you buy an OWB, most recommendation's will be for a gasification boiler with storage. I am sure that is what you meant, just wanted to clear it up.
3. "In the future I will add a water holding tank." I suggest that no matter what boiler you choose, that you add storage during the install, otherwise your "I work quite a bit" will have to change to (I work quite a bit, then I go home & spend all my spare time trying to get enough heat in my home because I have no storage to hold me over when I am at work). You & I want the same thing, namely that switching to wood is not a life altering experience. 2 or 3 big fires per day with the bulk of the energy going into storage accomplishes that, 8 or 9 little fires don't, as neither of us would be home to lite them. Easier for us ppl who work a lot to manage payments for something that works rather than adjust our schedules for something that does not work.
4. "Are there any gasification boilers that will take full logs." See I cheated & read ahead knew you meant to say gaser.....Most ppl state they can burn up to 6" rounds with little to no problem. That would be an excellent question for the more experienced users here, namely how full & how big (log diam) can you fill your boiler before it objects either by failing to gassify or by behaving like a run away train? Ask them to state the brand & model of boiler so you can judge what you are willing to accept for performance. I think the GARN would fare best with big rounds, makes sense round fire box, round wood continues to roll to center as it is burned. Square or rectangle fire box, probably bridges as it burns. One thing for sure, if I get a GARN, on day 2, I will find out how it works with a full firebox of large rounds. I just need to let it cool down to say 100 before I try this as there is no way I want to hear 2000 gallons of water boiling, at least not in my boiler. :bug:
4b. "I do not have a splitter, but will buy one if I have to." Buy one, that Elm may take many years to dry to 15-20% if not split. How patient are you & how much room do you have to store wood? While you wait for it to dry. Me...I have lots of both, not sure about your situation. Good luck with your info gathering & choices.
ISeeDeadBTUs said:But 350kBtu WITHOUT storage would be really bad for him.
ihookem said:I guess heaterman is right, geo thermal will never pay for itself. He could have got a top of the line Garn with a big storage shed and 5 years of firewood. He would have been cheaper off too. I am curious to see how it works.
heaterman said:ihookem said:I guess heaterman is right, geo thermal will never pay for itself. He could have got a top of the line Garn with a big storage shed and 5 years of firewood. He would have been cheaper off too. I am curious to see how it works.
It's a coin toss really. The bottom line with cord wood burning is that you have some or maybe total control over the price of your fuel. How knows where fossil fuels or cost per KW are going to be in 6 months let alone 5-10 years down the road. The flip side is that wood requires much more "user input" + the inevitable learning curve.......... often more of a straight vertical line the first year.
velvetfoot said:But isn't the cost of bought firewood somewhat indexed to the price of oil or gas? I find that's true around here.
Money doesn't go far nowadays, but how about insulating the heck out of the place first - even that isn't cheap though (foam or other major work). It'd be less effort and money to heat the house.
muncybob said:R 90...wow!! What is the insulation material used and how thick are those walls?
