So the blower is off if the tstat is satisfied? If so, wouldn't care for that either...
Kinda back to the wide open/ off except more precise
Sounds like they expect the thermostat to work well. I can see that allowing plenum temps to go that high would allow the fire to burn more slowly yet still be efficient, since less heat is being moved away form the firebox. Wouldnt work too well with a 165° heat dump though!So the blower is off if the tstat is satisfied? If so, wouldn't care for that either...
Yes, on some houses when it's really cold, or especially windy, BTU's must be pumped into the house non stop to keep from "falling behind"...I know that means you might need a bigger furnace, but I'm talking about a situation that would not be the norm, so the furnace is big enough 98% of the time.Kinda back to the wide open/ off except more precise... not sure how well that would work in my house being I have a furnace on the same level and need the blower running to push heat into the living areas. It would be nice to utilize the idle while still moving air around a bit anyway...
YupI can see another "Tundra fourm" in the near future...
Plus blower on/off would give that hot/cold feel that a forced air fossil fuel furnace has...lets the air stratisphy floor to ceiling...cold feet!![]()
Depending on which stat that is, they can be adjusted to stop frequent cycling.
Doesn't the jumper wire make it think the tstat is calling for heat non stop...run hot/burn fast/overheat the house in mild weather?
Probably a little cooler in your basement now with the extra front cover and cover insulation. (Better delivery efficiency)?
The funny thing is the T1 had a 200* (IIRC) high limit switch, and unless it fails closed (unlikely) it should open up if things get too hot, but when they first started cracking (and even later on) SBI was accusing people of over firing the T1, (leaving the manual switch on too long, etc) making them crack...but the HL switch should make "over firing" impossible (outside of propping the intake damper open or something stupid like that)...I guess where I'm going with this is it seems funny that 190* all day everyday is fine now, but 200* was over firing before? (I'm sure the firebox design has been improved, as far as longevity/durability)If there is any fire burning it should not take real long to reach 190°. In my situation I think it would gravity flow quite a bit at those temps. If your ductwork creates a heat trap then the blower will no doubt cycle regularly. But I agree it would be better to have a super low speed instead. Evidentally they don't consider 190 to be dangerously high, that's good to know.
What does the furnace do when you reload and press the button? Does it burn wide open for a period to 'fire' the load as the manuals recommend for the older models? I always feel like that process is unduly long and is the main culprit of the heat surge from a new load. If the Heat Commander can minimize that time and spread that heat out through the rest of the burn, it will definitely be an improvement.
Maybe @SBI_Nick can answer this as I'm not sure what is supposed to happen vs what is happening with my furnace.I don’t recall seeing an answer to this question.
Eric can you comment on this?
Also, is there any smoke that exits the door when you start the unit? If I read correctly, the door has to stay opened when reloading?
So basically an automated version of how the older tundras worked. Does the air control adjust often?Yes, when you press the reload button, the primary shutter opens fully and thr grill shutter opens about 30%. They remain open for a period of time to char and fire the wood, then close for optimal burn.
You only need to leave the door cracked for a minute or two while ensuring that the flames engage the wood (on a reload) or your kindling catches (on a cold start).
A Heat Commander update:
It's a properly chilly November day in Michigan's Upper Peninsula. The temp was 23*F at dawn and it's about 27*F with a stiff wind and flurries at 3:00pm.
Where you at in the Upper Peninsula?
So my question for either you or nick is after hitting that button can you literally walk away and the stove will take care of the rest? I ask because I work away a lot and the wife will not start the wood stove because she can’t get it to catch or will not manage the air controls haha. If this is the case I will be placing my order very soon because my electric bill is starting to scare meA Heat Commander update:
When I came downstairs this morning, it was 60*F on the first floor. I flipped on the pellet stove while I made coffee, answered emails, had breakfast, and planned out my day. That brought the downstairs to about 65*F at the center, and a bit cooler away from the pellet stove.
Around 9am, I turned off the pellet stove and ducked into the basement (with a fresh cuppa) and made a small fire in the Heat Commander. "Small" means about 8 or 10 wrist-size splits of maple, which is about 1/3 of what the furnace can take.
The thermostat is set to 70* and it's been between 70 and 73 since about 9:45am. As I type (and, actually, what made me think to make this post), the furnace is in "energy conservation, no call for heat" mode with a nice bed of coals that's still cycling the fan on and off.
So, just over 6 hours of good heat on a small load of small maple splits. It's 71*F on the first floor, 67*F on the second floor, and 62*F in the basement.
Of major note, I literally didn't touch the Heat Commander or the thermostat after lighting it this morning - we let the Heat Commander's computer manage the burn while we spent the day out in our family's shop, sewing and filling orders while our kiddos were in the house.
If things continue like this, it's going to be the easiest, warmest winter in the 10 years that we've lived here.![]()
