After install of a new Drolet HeatPro, I came here with questions on draft reading and control. Took the advice on here and have it dialed in I think. I installed a baro damper and also have a Dwyer Mark 2 working. Adjusted draft to be .05 with a hot fire. Should be right where it needs to be. The last 2 days have been the first time heating the house with the new HeatPro. 3500 sq ft. and it is doing great. Way more efficient than the old Powrmatic. Couple more questions however:
1. what is a decent flue temp? my infrared thermo read at around 300 degrees F. I bought Fieldpiece magnetic pitot tubes for my Dwyer and installed it between the stove and baro damper and it got hot enough to melt the rubber tube off. How can I keep this from happening?
2. The temp reading on the rear control board when burning a really hot fire (which I assume wat the plenum temp?) was a high of about 160s bot more steady at 140s. Is this a decent running temp? I have not checked the SP of the plenum.
