Hi everyone! I'm building a cape cod style house that's about 1600 sq. ft. I'm looking for an EPA certified zero clearance wood burning fireplace with as much window viewing space as possible. Any and all suggestions welcome. Thanks!
I was in your same position several years ago and went with a Bis ultima. I am somewhat less square footage than you at 1340 but I believe they have several other larger models available if need be. I believe they are now owned by lennox or possibly brentwood?? A google search of Bis Fireplace should get in the right area. I have nothing but good things to say about my unit very clean burning and very efficent.
The size of the fireplace is going to depend on how well sealed and insulated the house is. It's also going to depend on whether the fireplace is intended for nice fires on some nights and weekends or for 24/7 all season long heating. There is a wide range of options, but knowing this info will narrow down the list.
That could be a challenge with a nice, tight house. A freestanding catalytic stove may be a better guarantee for 24/7 heating. Otherwise look at zc fireplaces in the 2 to 2.5 cu ft range. The Heat & Glo Northstar is a little larger, but is a good 24/7 heater.
I'm attaching a zero clearance FP list I created to help review all the specs. There are certainly other ZC models which are not included on this list, but this should provide a good starting point. Generally speaking, all the models on my list have been positively spoken about on heart.com.
Like others have said - I think it comes down to size of the firebox, the technology (cat Vs non-cat) and aesthetics (modern Vs traditional).
we are enjoying our Osburn Stratford. it is rated at 74k btu and 2100sqft. our home is an awkward 2500sqft and we keep our living space comfortable 70-72 when outside is above 20 deg F. below 20deg F and we push it hard to keep heat pump (electric strips at that temp) quiet. our climate is fairly mild and we can get 6 hours of heat no problem and plenty of coals to relight after 8+
Matt for a more complete listing you may want to add the Regency R90 & EX90 and Kozy Z42 fireplaces to that list. Buck also has ZC enclosures for their model 20ZC and 80ZC fireplaces.
