jjam
if I was to install a stove I would go with a Vermont castings because of the top loading
encore or defiant depending on size needed
I initially considered VC stoves. I do love the top loading feature, but they are cast iron and I fear the heat would be too intense for the small living area; I want gentle steady heat. After doing research and collecting advice I've whittled my list down to the Hearthstone Heritage or a BK Ashford.if I was to install a stove I would go with a Vermont castings because of the top loading
Thank you, this very is helpful. I've not yet been able to find an image of the back of the Hearthstone.As for the back side of the Hearthstone I can't speak to the Heritage but my Mansfield is panels of soapstone on the back. Much like the sides. In a center room install you wouldn't need the heat shield.
I sell them , and I'm WETT certified an installer with 25 years experience ,![]()
ok I'm not going to argue/ but it is from the owners mouth, also in most installs you can not use any 90 degree elbows, i suppose you will say that's not true as well heheAnd what you keep saying simply is not true.
Definitely check that with a dealer but I would imagine it is the same.Thank you, this very is helpful. I've not yet been able to find an image of the back of the Hearthstone.
Meaning in chimneys, right? 90º elbows in stove pipe are common.also in most installs you can not use any 90 degree elbows
Are you talking THE owner of the company Blaze King?ok I'm not going to argue/ but it is from the owners mouth, also in most installs you can not use any 90 degree elbows, i suppose you will say that's not true as well hehe
It's listed as a True Hybrid as is my Mansfield and yes you can burn minus the cats on the secondarys. The pic on the website shows a handle, like mine too engage the cats.Thanks. I believe the Heritage is a hybrid in that it has both a cat and a double burn. From what I've researched you can leave the cat disengaged and it will run in secondary combustion (pls correct me if I'm wrong).
That's pure BS. BK stoves are made in the Pac NW's milder climate. They are better for mild weather burning than several stoves.it was the owner of blaze king that told me that by the way hehe
When was Blaze King founded?
Blaze King was founded in 1977.Where is Blaze King headquartered?
Blaze King is headquartered in Penticton, Canada.What industry is Blaze King in?
Blaze King’s primary industry is Distributors/Wholesale.Is Blaze King a private or public company?
Blaze King is a Private company.What is the current valuation of Blaze King?
The current valuation of Blaze King is 00.000.What is Blaze King’s current revenue?
The current revenue for Blaze King is 000000.When was Blaze King acquired?
Blaze King was acquired on 27-Feb-2015.Who acquired Blaze King?
Blaze King was acquired by Decisive Dividend.
Blaze kings biggest strength is their ability to run low and slow better than any other stove on the market while still burning clean. That and the even heat due to the thermostat but others have that. But you are absolutely not correct that they are only good for cold climates. In fact I would say the opposite they are better suited to milder climates. Not that they can't be used in cold areas but that isn't where they really shinei do not think there is much difference in the air control , but the cat on the bz is very large
and works like a restrictor, very low temp on the flue gases 300-400 degrees I have seen customers run them low then end up with a chimney fire / because they are using a stove meant for very cold
Are they "somewhat lower" on the high end? Are they based upon the same method? If not, then the values are not comparable. We certainly do not make the highest BTU producing stoves, but if comparable test method data is used, the difference is negligible.I think that *as long as the BTU output of the stove meets the needs of the home*, having a BK and running it high is nice too - because the thermostat allows for that to be very even. My experience with my previous stove (an old cat stove) is that running a non-thermostat stove high results in larger temperature fluctuations (due to larger heat output changes over the burncycle of a non-thermostat stove).
jjam is not wrong in saying that there are a lot of BKs in the far cold north. Evidently they meet a need there too.
Of course, one has to take into account their somewhat lower max output as other stoves of the same firebox volume when one chooses a stove for ones home.
