Hello all, Got a question I have a ranch home with electric baseboard heat. I have a Jotul System 18 fireplace insert that was installed in the house in 1983. I burn alot of wood in a season and I would have to say that pushing the insert to produce more heat would only burn more wood. Was going to get a wood furnace the one in question was Drolet Heatmax. We stopped at a local business called Stoves and Stuff located outside Tamaqua Pa. While looking at the stoves and inserts we spoke with a salesperson that introduced us to a Lopi fireplace insert Hybrid.
My home is a ranch style house with the fireplace in the basement. I would have to say around 2000 sq ft.at the most. I have no duct work and no chimney on the "man side of the basement" where the wood furnace would go so that would have to be made and installed.
This is what I have now:![Need some advice Lopi insert or Wood Furnace Need some advice Lopi insert or Wood Furnace](https://www.hearth.com/talk/data/attachments/116/116187-3e99f0544e7ef12d1680ce645a19f35d.jpg)
My stairs to my kitchen and living room are to the left of My St Bernard. Two air returns in this side of the basement. My chimney is 12 inch teracotta lined and about 24 feet high.
This is what we were shown:
![Need some advice Lopi insert or Wood Furnace Need some advice Lopi insert or Wood Furnace](https://www.hearth.com/talk/data/attachments/116/116188-751c74eece99bb48255c2e95b8142bbf.jpg)
This large 3 cubic foot insert features clean burning Hybrid-Fyre Technology. Hybrid Technology is a fusion of advanced secondary combustion with the addition of catalytic assist technology. Primary combustion burn occurs in the firebox with our secondary tubes re-burning gases before they leave the firebox, any remaining unburned gases then through a catalytic combustor leaving virtually no smoke to exit the appliance. The net result of this is a super clean burning insert, with emissions of just .58 grams per hour. Also with that reduction in emissions comes almost zero carbon mononxide. We are taking clean burning to an unmatched level of efficiency...
Now with GreenStart Option. GreenStart is a patent-pending ignition system for the modern wood burner; just load your wood and push a button! We've completely eliminated slow, cracked open door startups and laboring over fickle newspaper.
Click here to watch a GreenStart video demonstration.
The Large Flush Wood Hybrid-Fyre Insert features a huge 319 sq. in. fire-viewing area, twin 90 CFM convection fans and has the option of adding the Revolutionary GreenStart Option. GreenStart is a patent-pending ignition system for the modern wood burner; just load your wood and push a button
Specs:
Heating Capacity Up to 2,500 Sq. Feet
Weight 530 Lbs.
Maximum Burn Time 12 Hours
Firebox Size 3.0 Cubic Feet
Maximum Log Size 24 "
Emissions 0.58 Grams Per Hour
Efficiency 80.3%
Construction 5/16" to 1/4" Steel Plate
- Read more..
. Our overall efficiency for this Large Flush Wood Hybrid-Fyre Insert is over 80%. What this means is more heat from less wood, and greater savings on your heating cost! This insert will heat up to 2,500 sq. feet, with up to 10 hour burn times and can accept 24" wood.
Specs:
Weight 530 Lbs.
Efficiency 80.3%
![Need some advice Lopi insert or Wood Furnace Need some advice Lopi insert or Wood Furnace](/talk/proxy.php?image=http%3A%2F%2Favalonfirestyles.com%2Fimages%2Fimages_Numbered%2F108333.jpg&hash=75fce964357fb21ea3d573e3239d1676)
![Need some advice Lopi insert or Wood Furnace Need some advice Lopi insert or Wood Furnace](/talk/proxy.php?image=http%3A%2F%2Favalonfirestyles.com%2Fimages%2Fimages_Numbered%2F108334.jpg&hash=792d7c19b28ea1a4838ce3d737e5c109)
